on 26-03-2023 11:21
Sorry to trouble you but I have a problem with the Wi-Fi on the Virgin hub 4 I have the 1GB version now it was fine I had the ssid showing in my connections on the pc with both Wi-Fi connection there no problems until last when the daughter said she had no Wi-Fi when I was at work so she turned the hub off and back on but still no Wi-Fi so I went into the hub 4 settings on 191.168.0.1 address looked and see that there was no Wi-Fi so went advanced wireless wireless signal and see the
where both disabled so I changed them to enable and both on auto channel applied and closed the hub software
Then to my surprise no wifi so checked it all again and both the 2.4 qnd 5 GHz was both disabled again I tried resetting the hub and still this happens, what's wrong with my hub please help.
Thanks John 🙂
26-03-2023 18:31 - edited 26-03-2023 18:40
How did you reset it? Make sure you do a full factory reset (having made sure the passwords are visible on it) - hold the reset button in for a full minute before releasing and letting it settle.
Are wired connections working?
What lights are on?
Anything showing in the status pages?
on 26-03-2023 20:46
On the status page WiFi is off
Ethernet is fine and shows as connected now i done the reset on the hub settings
Thanks for your help John 🙂
on 26-03-2023 21:30
So is the WiFi working now?
on 27-03-2023 07:18
no wifi just wont turn on in the software nore will wps button connect to anything like i said i go in to the hub settings you tick the boxes to turn on the wifi save it come out look on the pc in connections still no hub 4 available so i check again in the hub software on pc an its turned off again thanks John, I will try the full reset today just not got round to doing it yet i have another wifi hub i was using yesterday
on 27-03-2023 09:48
try full reset. If still not working must be a bug or faulty hub I guess.
