8885
Message 1 of 7
Wifi not working every evening ?
Why us the wifi suddenly so poor, everyone in household is not having connection issues?
Is it convenienty got poor as I'm near the end of my contract period?
  • 2.41K
  • 131
  • 380
chenks
Problem sorter
Message 2 of 7
Re: Wifi not working every evening ?
just wifi or the actual internet connection?
does it work fine when using ethernet?
8885
Message 3 of 7
Just wifi as all devices are handheld so don't use ethernet
  • 2.41K
  • 131
  • 380
chenks
Problem sorter
Message 4 of 7
can you test using ethernet though?
as we need to ascertain if you just have a local wifi issue, or if your actual internet connection is the problem - they are not the same thing.
8885
Message 5 of 7
Hi.
No cant plug a ethernet into any device that we use.
Have to reboot router every day as get exclamation mark next to wifi symbol
  • 2.41K
  • 131
  • 380
chenks
Problem sorter
Message 6 of 7
post your router stats (go to the login page of the hub and click on "check router stats".
8885
Message 7 of 7
