TheMalt1
Wifi not working but Ethernet is fine
  • 13.23K
  • 1.01K
  • 3.08K
Re: Wifi not working but Ethernet is fine
lot more info needed - what have you done to test the wifi - have you checked its turned on in the hub -
____________________
Tony
  • 12.63K
  • 482
  • 1.13K
Best guess the hubs wireless has gone faulty.
You could ask for a new hub or use modem mode and get your own wireless router with 1Gb ports.
  • 13.23K
  • 1.01K
  • 3.08K
do yo never get sick of typing that and banging the drum
Tony
TheMalt1
Called Virgin and as soon as got through WiFi came back to life! Not sure if it’s just a temporary glitch? Will continue to monitor it. Thanks for replying.
  • 12.63K
  • 482
  • 1.13K
What firmware is your hub on?
