Wifi network not secure
iainplummer
I'm getting a message from windows 10 saying that my wifi connection is not secure and the security standard will soon be obsolete. I've had the same router for about 10 years. I just upgraded my broadband and tv package. I got a new box but not a new router. Do I need to change my router ?
2 REPLIES 2
If you still have the original Superhub 1, you should be getting a free upgrade to the Hub 3.  Phone in and request a replacement Hub 3.
Gareth_L
Hello iainplummer
I have just checked from here and you do still have the original Superhub
I can ask an engineer to come out and swap this over
Sadly we are not able to sent them out right now
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
