Wifi keeps dropping
Hi our wifi seems to drop out randomly on a daily basis and its making my working from home a nightmare.  We've run all the tests and there's no issues - I can't keep turning the router on and off each time as it doesn't fix it for very long.  Have tried calling but the wait times are just too long.
Help
  • 7.01K
  • 517
  • 907
Legend
Re: Wifi keeps dropping
It can be difficult diagnosing problems without some basic information.
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting the area. Be aware that it isn't a manned line.
What is your connection like with a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
Thanks - will try and work out what I need to do.  Not great with too much technical stuff.   I get the wifi symbol with a ! and connected without Internet when u try to connect.
You are not alone Lisa. I have tried all the remedies as suggested by Virgin but have been unable to achieve 108MB since July 9th 2020.
  • 7.01K
  • 517
  • 907
Legend
Have you got an ethernet cable connectable device can you use ?
Mike Robinson
Will try that later when my husband gets home.  Managed to get through to Virgin so will see what they say as well.
