  • 22
Message 1 of 17
Wifi keeps dropping out
Can anyone help me please? Since the initial lockdown and working from home I noticed that every now and again my wifi signal would drop out and kick back in again so not really a massive issue.
However over the last few weeks it has increasingly got worse, Last week i was on holiday so it never got used but last night all 3 of us in the house were using our devices when it just dropped out and kicked back in 2 minutes later.
Watching even 2 minute videos on youtube is becoming a nitemare, I have reset the router many times and searched the internet for remedies but nothing resolves it.
Any help would be greatly appreciated.
  • 11.77K
  • 917
  • 1.51K
Message 2 of 17
Re: Wifi keeps dropping out
What is your connection like using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
  • 22
Message 3 of 17
Hi, I am only getting 28mbps download and 3.30 upload through my ethernet connected pc and i pay for 450mbps.
  • 11.77K
  • 917
  • 1.51K
Message 4 of 17
Can you Login to the Hub Settings and navigate to the Connected Devices page - what does it report the 'connection speed’ as for the cable connected device you used for the speed test ?
Mike Robinson
  • 11.77K
  • 917
  • 1.51K
Message 5 of 17
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Copy and paste the contents of the Downstream, Upstream, Configuration and Network Log tabs onto here, if you get a yellow / straw box warning click the Post button again. Use one post for each tab if you wish. Please do not use screen grabs.
Mike Robinson
  • 22
Message 6 of 17
My BQM
  • 22
Message 7 of 17
11390000000.937256 qam1
21470000002.738256 qam2
3155000000137256 qam3
4163000000-1.237256 qam4
51710000001.237256 qam5
61790000002.538256 qam6
7187000000037256 qam7
8195000000-1.238256 qam8
9203000000138256 qam9
102110000001.438256 qam10
11219000000-1.737256 qam11
12227000000-1.237256 qam12
132350000000.738256 qam13
14243000000-0.737256 qam14
15251000000-3.538256 qam15
16259000000-1.737256 qam16
17267000000-0.538256 qam17
18275000000-1.737256 qam18
19283000000-338256 qam19
20291000000-1.238256 qam20
21299000000-0.538256 qam21
22307000000-337256 qam22
23315000000-2.537256 qam23
24323000000-0.538256 qam24
1Locked37.32184155251204930
2Locked38.9136630721741600
3Locked37.6357591962431511
4Locked37.63028556122393682
5Locked37.6140480469184
6Locked38.68380595174
7Locked37.6160473276111
8Locked38.61958124170541
9Locked38.61353614104343
10Locked38.698598899164
11Locked37.62366425317609
12Locked37.32673466189684
13Locked38.6190503177118
14Locked37.61966012204824
15Locked38.62439353443183
16Locked37.61995418272439
17Locked38.6108526026013
18Locked37.6120898836631
19Locked38.9140362370443
20Locked38.680538118224
21Locked38.692927346743
22Locked37.61753205218287
23Locked37.62379258142192
24Locked38.617569334014
  • 22
Message 8 of 17
13260003449512064 qam5
23940000051512064 qam4
35370000049.8512064 qam2
44620000051512064 qam3
1ATDMA00270
2ATDMA00180
3ATDMA00220
4ATDMA00220
  • 22
Message 9 of 17
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt062-b.cm
SFID605140
Max Traffic Rate402500089
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID605139
Max Traffic Rate38500089
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
  • 22
Message 10 of 17
TimePriorityDescription03/11/2020 17:08:44noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 17:06:26Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 17:03:34criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:56:54Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:55:14criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:53:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:48:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:47:22Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:46:35criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:45:46criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:44:28Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:42:38criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:37:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:34:37criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:29:56Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:25:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:22:41criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:22:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:21:15criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;03/11/2020 16:21:2criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
