on 19-09-2021 16:41
Hi my wifi keeps dropping out or becoming very weak. I’ve reset my box and I only have two devices connected but even that seems too much!
Answered! Go to Answer
19-09-2021 17:20 - edited 19-09-2021 17:20
Sounds like the Hub4. If the ring remains white it suggests it is still connected ok to the network. So it could just be a wifi issue. Have you looked through the "Wifi Wins" posts on the right hand side of the forum page to see if there is anything in there that helps.
If it really is down to a wifi issue the ethernet connectiion test would prove that.
To address the wifi issues, VM now supply “wifi Pods” (no longer doing “boosters”). Pods are free to customers on 1GB or Ultimate Oomph packages - is that you?
If not you will be charged £5/month. Its a simple solution and should work for you. However, you would soon pay off that cost by buying a "better" wireless solution that will be yours to own and use forever but it isn’t the simple plug and play option of the Pod(s).
on 19-09-2021 16:46
on 19-09-2021 17:11
It’s only wifi. I don’t use the Ethernet cable for devices I think the hub is called hub 4. It has a white light stripe around it which stays lit. Just to load this message meant me turning off my wifi in order to load the page
on 19-09-2021 17:44
Thank you for your help! I need an adapter to test the Ethernet so I’ll try that later this week
i didn’t want to go down the route of boosters, I thought the package I pay for would be enough without having to add extras
on 21-09-2021 17:50
Hi @Kate15,
Thank you for your posts and welcome to our community forums. We're here to help.
I'm sorry to hear you've had some Wi-Fi trouble lately, but I can see that @jbrennand has offered some help and support. Do you still need our help with this today?
