theodorghinea
  • 18
Message 1 of 20
Wifi / ethernet keeps disconnecting
We are a couple, both working from home and we are having problems with our internet.
It keeps disconnecting every day, being dificult to do our work properly.
I have checked the cables, rebooted the hub, still having this issue.
tehwolf
  • 1.52K
  • 243
  • 367
Superfast
Message 2 of 20
Re: Wifi / ethernet keeps disconnecting
are you both connecting to teh hub over wifi?
whilst inconvenient, it would be useful to check if you get the same issues whilst connected to the hub via ethernet to see if the problems persist over a cable.. it will help narrow down where the issue is..
theodorghinea
  • 18
Message 3 of 20
Both computers via ethernet cable.
tehwolf
  • 1.52K
  • 243
  • 367
Superfast
Message 4 of 20
ok - can you set up a BQM please - then have a look at the "Live Graph" and underneath, select the "create sharing link" (or similar) post that link back here.
in addition, browse to you hub on http://192.168.0.1 - don't log in, click on Router Status.  Copy and paste the tables from Upstream, Downstream and Network Log back into this thread - one post per tab (it won't all fit into a single post).
theodorghinea
  • 18
Message 5 of 20
12030000005.438256 qam9
22110000005.538256 qam10
32190000005.438256 qam11
42270000005.337256 qam12
52350000005.338256 qam13
62430000005.338256 qam14
72510000005.438256 qam15
82590000005.438256 qam16
92670000005.338256 qam17
theodorghinea
  • 18
Message 6 of 20
Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
13940000043512064 qam2
22580003345.5512016 qam4
34620000043512016 qam1
43260000943.8512016 qam3
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
1ATDMA0040
2ATDMA0040
3ATDMA0040
4ATDMA0050
theodorghinea
  • 18
Message 7 of 20
12/02/2021 13:14:48noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
12/02/2021 13:14:39Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 23:22:19criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 15:30:53ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2021 05:28:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0
theodorghinea
  • 18
Message 8 of 20
I don't know how to do the other thing with BQM.
tehwolf
  • 1.52K
  • 243
  • 367
Superfast
Message 9 of 20
so you need to select teh whole table on the downstream tab (and network log) you need to scroll down the screen to select the full table..
That aside, there's a more obvious problem in the upstream - three out of four of your channels are at 16QAM and should be at 64 - this will almost certainly be impacting your performance.
Setting up the BQM isn't would be really helpful..  Follow the link i posted above and click Create New Monitor (you will have to register for an account before it will let you do this) it should automatically populate the "difficult" information (i.e. your IP address etc..) so just give it a name (whatever you like) and then:
(I'm gonna steal @MikeRobbo's instructions for doing so - see below..)
theodorghinea
  • 18
Message 10 of 20
