on 08-02-2022 11:50
We have a Hub 3.0 and the wifi drops out continuously- sometimes every few minutes! I’ve tried resetting and restoring, moving the hub, moving the booster and nothing helps.
My son uses a wired connection for PS4 and also reports it is bad, but I know this is the broadband not the wifi.
We’ve had this trouble before and had a new hub and an engineer out, it seemed to be better for quite a while but now worse than ever. I wonder what other provider I can even switch to for fibre optic - any tips??
on 08-02-2022 12:03
on 08-02-2022 12:11
Thank you, can you tell me how to do this please?
on 08-02-2022 12:40
How to get stats from a VM hub
Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
on 08-02-2022 12:44
1 | 331000000 | 6.5 | 40 | 256 qam | 25 |
2 | 203000000 | 5.5 | 38 | 256 qam | 9 |
3 | 211000000 | 5.1 | 38 | 256 qam | 10 |
4 | 219000000 | 5.3 | 40 | 256 qam | 11 |
5 | 227000000 | 5.3 | 38 | 256 qam | 12 |
6 | 235000000 | 5 | 38 | 256 qam | 13 |
7 | 243000000 | 4.9 | 38 | 256 qam | 14 |
8 | 251000000 | 5 | 40 | 256 qam | 15 |
9 | 259000000 | 5.3 | 38 | 256 qam | 16 |
10 | 267000000 | 5.5 | 38 | 256 qam | 17 |
11 | 275000000 | 5.6 | 38 | 256 qam | 18 |
12 | 283000000 | 6.1 | 40 | 256 qam | 19 |
13 | 291000000 | 6.3 | 40 | 256 qam | 20 |
14 | 299000000 | 6.4 | 38 | 256 qam | 21 |
15 | 307000000 | 6.1 | 40 | 256 qam | 22 |
16 | 315000000 | 6.5 | 40 | 256 qam | 23 |
17 | 323000000 | 6.4 | 40 | 256 qam | 24 |
18 | 339000000 | 6.9 | 40 | 256 qam | 26 |
19 | 347000000 | 6.8 | 40 | 256 qam | 27 |
20 | 355000000 | 6.5 | 40 | 256 qam | 28 |
21 | 363000000 | 6.1 | 38 | 256 qam | 29 |
22 | 371000000 | 6 | 40 | 256 qam | 30 |
23 | 379000000 | 6 | 38 | 256 qam | 31 |
24 | 387000000 | 6 | 40 | 256 qam | 32 |
1 | Locked | 40.3 | 167 | 11331 | ||||||||||||||||||||||||||||||||||||||||||||||||
2 | Locked | 38.9 | 130 | 2191 | ||||||||||||||||||||||||||||||||||||||||||||||||
3 | Locked | 38.9 | 207 | 2788 | ||||||||||||||||||||||||||||||||||||||||||||||||
4 | Locked | 40.3 | 169 | 3048 | ||||||||||||||||||||||||||||||||||||||||||||||||
5 | Locked | 38.9 | 229 | 3148 | ||||||||||||||||||||||||||||||||||||||||||||||||
6 | Locked | 38.6 | 1274 | 8639 | ||||||||||||||||||||||||||||||||||||||||||||||||
7 | Locked | 38.9 | 1376 | 8974 | ||||||||||||||||||||||||||||||||||||||||||||||||
8 | Locked | 40.3 | 1000 | 9692 | ||||||||||||||||||||||||||||||||||||||||||||||||
9 | Locked | 38.6 | 1453 | 9013 | ||||||||||||||||||||||||||||||||||||||||||||||||
10 | Locked | 38.9 | 1155 | 9975 | ||||||||||||||||||||||||||||||||||||||||||||||||
11 | Locked | 38.9 | 414 | 10753 | ||||||||||||||||||||||||||||||||||||||||||||||||
12 | Locked | 40.3 | 546 | 10229 | ||||||||||||||||||||||||||||||||||||||||||||||||
13 | Locked | 40.3 | 1332 | 9111 | ||||||||||||||||||||||||||||||||||||||||||||||||
14 | Locked | 38.9 | 1178 | 10143 | ||||||||||||||||||||||||||||||||||||||||||||||||
15 | Locked | 40.3 | 1148 | 8973 | ||||||||||||||||||||||||||||||||||||||||||||||||
16 | Locked | 40.3 | 1071 | 9755 | ||||||||||||||||||||||||||||||||||||||||||||||||
17 | Locked | 40.3 | 922 | 10347 | ||||||||||||||||||||||||||||||||||||||||||||||||
18 | Locked | 40.3 | 172 | 11554 | ||||||||||||||||||||||||||||||||||||||||||||||||
19 | Locked | 40.9 | 352 | 10969 | ||||||||||||||||||||||||||||||||||||||||||||||||
20 | Locked | 40.9 | 247 | 11624 | ||||||||||||||||||||||||||||||||||||||||||||||||
21 | Locked | 38.9 | 323 | 10868 | ||||||||||||||||||||||||||||||||||||||||||||||||
22 | Locked | 40.9 | 417 | 10346 | ||||||||||||||||||||||||||||||||||||||||||||||||
23 | Locked | 38.9 | 1117 | 9495 | ||||||||||||||||||||||||||||||||||||||||||||||||
24 | Locked | 40.3 | 1025 | 9365Upstream bonded channelsChannel Frequency (Hz) Power (dBmV) Symbol Rate (ksps) Modulation Channel ID
Upstream bonded channelsChannel Channel Type T1 Timeouts T2 Timeouts T3 Timeouts T4 Timeouts
on 08-02-2022 12:45
08/02/2022 12:34:20 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 12:34:4 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 12:07:15 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 12:06:30 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 12:06:24 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 12:06:24 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 12:06:23 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 12:06:17 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 12:06:13 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 12:06:13 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 12:06:12 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 10:45:52 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:40 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 09:19:33 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 09:15:0 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:37 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 09:02:40 | notice | Unit has been restored to factory defaults from a software issued command;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
08/02/2022 08:55:38 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 08-02-2022 12:48
Virgin media website now saying this, feels like stalling for 24 hours rather than someone is actually looking into it!
thank you so much for replying and look forward to what you think 😊
on 08-02-2022 15:12
You have far too many Post RS errors, and a few Pre RS errors.
I noticed also from the logs that you've been entering an incorrect username/password.
When logging into the hub you should enter the WiFi network, and the Settings password (not the WiFi password) which are printed on the base of the computer.
If you can manage to log in there correctly then go to Admin > Reload and Rebbot and click on Restore to factory default.
This will reset the Pre RS erros and Post RS errors to zero so that the WiFi gurus on the forums can get a better idea of how the hubs performing. It may also fix the speeds.
If you can't manage it that way then try the following to factory reset the hub.
Keep the hub switched on and disconnect any ethernet connections, then push the reset button firmly with a paperclip or something similair. keep it pressed in for around a minute.
Wait around 10 minutes and it should revert to factory settings. You can now reconnect the ethernet cables.
If you previously changed your router password it won't work and you will have to use the one printed on the sticker on the router. You can always change it again by going into the settings.
It will also help if you can set up a BQM (Broadband Quality Monitor) at thinkbroadband.com - this will give you an insight into what is happening with the signal at the other side of the Hub.
It will take a few hours to get any kind of trend showing although you can post the link straight away.
Once it's set up on Think Broadband go to your BQM and under the options you will see
Today | Previous Days | Edit | Delete | Share
Click on the Share option and on the screen that opens click on Share
On the next screen click on Share Live Graph
Copy the text in the Direct Link box (beware there may be more text than you can see)
In the URL box paste the link you copied and then click OK.
on 08-02-2022 15:25
on 08-02-2022 15:40
Thank you for taking the time to reply to me. I have already done a factory reset today, the incorrect password was as a result of that a. defaulting to factory password and b. Safari wrongly saving it 🤦♀️. It is necessary to do any other reset?
I could attempt the BQM part tomorrow. However, a virgin equipment check did come up with that I had an intermittent signal, advised me to check my connections and that after 24 hours they would send an engineer if it wasn’t resolved (they are apparently working on it’.
many thanks again
