I have the same. Check for overheating first by touch and then run a diagnostic test by logging in to the hub at 192.168.0.1, home tab, Network Diagnostic Tool. Run it and it will advise if the hub is really overheating. If it is then move it to a more ventilated place and give it a rest by unplugging it for half an hour. If still a problem after that call VM.
