Wifi dropping in and out
Kath_i01
  • My wifi keeps dropping in and out for the past week. I’ve got a external TP-link router so I use the virgin router in modem mode.
I’ve tried restarting the hub, factoring resetting, changing it back to router mode, using a different coax cable. And nothing seems to fix it, it just turns on for 10 mins and the stops, looking like it rebooted itself, so it’s off for another 30-45 mins.This is very frustrating as I work from home and need constant signal to work.
We had a technician come out last week and he fixed some cables on our street but the problem seems worse.
Since I’ve troubleshooted everything, the only logical explanation is the router is broken. Can I please get a replacement router?
Many thanks
5 REPLIES 5
Lets look at its data - can you do this
_______________________________
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. On the first page up dont login (unless you have the Hub4/5 - when you do login) just click on the “router status” icon/text at bottom-middle (Hub3/4) or top/right (SH’s) of the Login page and then Navigate to these “pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs page. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again. If character limits are “exceeded” - just do two posts
If you haven’t already, set up a free, secure and “offlsite” - “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph”. Click the lower link (Share Live Graph) then click generate. Copy the text in the Direct Link box, beware, there may be more text than you can see. On here click the Link icon (2 links chain to the left of the camera icon) In the URL box paste the link you copied and then click OK
Thanks for the quick response, here's the tables:
11390000005.840256 qam1
21470000005.540256 qam2
31550000005.340256 qam3
41630000005.640256 qam4
51710000005.840256 qam5
61790000005.940256 qam6
7187000000640256 qam7
8195000000640256 qam8
9203000000640256 qam9
102110000006.140256 qam10
112190000005.838256 qam11
122270000005.640256 qam12
13235000000640256 qam13
14243000000640256 qam14
152510000005.540256 qam15
162590000005.640256 qam16
172670000006.340256 qam17
182750000005.940256 qam18
192830000005.840256 qam19
20291000000640256 qam20
212990000006.540256 qam21
223070000006.540256 qam22
233150000006.440256 qam23
243230000006.340256 qam24
1Locked40.3920
2Locked40.3120
3Locked40.9240
4Locked40.9490
5Locked40.31060
6Locked40.3230
7Locked40.9230
8Locked40.9190
9Locked40.3220
10Locked40.3160
11Locked38.6190
12Locked40.9180
13Locked40.3140
14Locked40.380
15Locked40.970
16Locked40.3230
17Locked40.9120
18Locked40.970
19Locked40.960
20Locked40.350
21Locked40.350
22Locked40.9100
23Locked40.960
24Locked40.390
16030000046.8512064 qam1
23940000046512064 qam4
34620000046.3512064 qam3
45370031246.8512064 qam2
1ATDMA0010
2ATDMA0010
3ATDMA0000
4ATDMA0000
16/08/2022 18:21:53noticeLAN login Success;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
16/08/2022 18:21:48Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:43criticalNo Ranging Response received - T3 time-out;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
16/08/2022 09:23:22noticeLAN login Success;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:44criticalNo Ranging Response received - T3 time-out;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
16/08/2022 08:38:28noticeLAN login Success;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
16/08/2022 08:38:13Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
16/08/2022 04:42:23Warning!RCS Partial Service;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
16/08/2022 04:42:23criticalNo Ranging Response received - T3 time-out;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
16/08/2022 04:42:22Warning!RCS Partial Service;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
16/08/2022 04:42:22criticalNo Ranging Response received - T3 time-out;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
16/08/2022 04:42:21criticalNo Ranging Response received - T3 time-out;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
16/08/2022 04:42:21Warning!RCS Partial Service;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
16/08/2022 04:42:20criticalNo Ranging Response received - T3 time-out;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
16/08/2022 04:42:20Warning!RCS Partial Service;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
16/08/2022 04:42:18criticalNo Ranging Response received - T3 time-out;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
16/08/2022 04:42:5Warning!RCS Partial Service;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
16/08/2022 04:42:5criticalNo Ranging Response received - T3 time-out;CM-MAC=XXXXX:db;CMTS-MAC=XXXXX;CM-QOS=1.1;CM-VER=3.0;
VM will not give you a replacement TP link router.😁
How is the connection by wire to the hub in modem mode? if good your router needs replacing not the hub.
Zach_R
Hi @Kath_i01,
Thank you for your posts and welcome to our community forums. We're here to help.
I am so sorry to hear you've been facing some problems with your connection recently. Are these ongoing for you today? If they are, would you mind setting up and sharing a live BQM so we can have a closer look at the connection in real-time?
Zach - Forum Team
New around here? To find out more about the Community Forums, take a look at our FAQs!
