Wifi dropping a couple of times a day - kicks Samsung TV and Nanit off completely
ForumUser102
I'm a new Virgin Media user, it's my first month.
From the first week I've had the service dropping a few times a day for no apparent reason. Here's what I've seen:
  • Whilst my iMac and iPhone reconnect seamlessly when it does come back up, my TV (Samsung and Nanit baby monitor) Get kicked off the wifi and borks their settings, requiring a complete resync to the Wifi.
  • Downtimes last from seconds to minutes. The worst was a few hours.
  • Sometimes this happens at night so we can't see both our baby monitors meaning i have to go into their room, press a physical button on them to start the sync again to wifi.
  • The TV is literally next to the hub, so it's not distance or anything like that.
I've experienced service dropping out before, that's why I moved to Virgin from Vodafone 5G Gigacube, but this is insane.
If someone from Virgin is reading this, can you check the outages on my account? Also what is the resolution here.
Hopefully, there are some settings I can change.
11 REPLIES 11
Can we just check first....
.... are the issues only evident on wifi connections or do you see them at the same times on devices connected on an ethernet cables? If you don't know, can you check with one on ethernet to help diagnose whether it is just a wifi issue or it could be network connection related?
What Hub model is it? What are the various Hub lights showing/doing when this happens?
gary_dexter
Do wired devices drop out as well?
Hi John,
Thanks for the reply.
It's all wireless in my house right now. I don't have any wired devices.
However I can say the router is in the same place as the previous provider.
The Hub model is 3.0 - i think the light was yellow once and the other lights were off but I'll remember to take a photo next time. Other than the hour long outage, by the time I'm booted off a zoom call or disconnected from the Playstation, it's already back on.
Hi Gary,
Sadly I don't have any wired devices. I spend most of the day on an iMac in home office setup.
Cheers
You can connect any Mac to ethernet with the right adapter - I have them for all my Powerbooks and Airs. Worth getting one for the port on the iMac and a long run of Cat5e/6/7 cable (less than a tenner) for testing purposes - stick it in the bits drawer when not in use.
It may be a wifi only issue but lets see if there is any obvious network connection issue - can you do this...
_____________
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. On the first page up dont login just click on the “router status” icon/text at bottom-middle (Hub3/4) or top/right (SH’s) of the Login page and then just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs page. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again. If character limits are “exceeded” - just do two posts
Also... if you haven’t already, set up a free, secure and “offlsite” - “Broadband Quality Monitor” to continually monitor the state of your connection and record any true network dropouts , latency issues, packet drops, etc - it will thus allow you to differentiate between those and simple wifi dropouts. It does it 24/7/365 and it keeps a visual record of any/all of your network disconnections, useful data to have to match to the Network logs (in your Hub settings) and also in discussions with VM - note it will take a few hours to start seeing a sensible picture - post up the “link” to the “share live graph”. Click the lower link (Share Live Graph) then click generate. Copy the text in the Direct Link box, beware, there may be more text than you can see. On here click the Link icon (2 links chain to the left of the camera icon) In the URL box paste the link you copied and then click OK
Cheers, heres each one below. Will give the network monitor a go too.
Downstream
13307500007.540256 qam25
22027500008.440256 qam9
32107500008.140256 qam10
42187500008.140256 qam11
5226750000840256 qam12
6234750000840256 qam13
72427500007.940256 qam14
82507500007.540256 qam15
92587500007.540256 qam16
102667500007.440256 qam17
112747500007.140256 qam18
122827500007.540256 qam19
132907500007.940256 qam20
14298750000840256 qam21
153067500007.840256 qam22
16314750000840256 qam23
173227500007.840256 qam24
18338750000840256 qam26
193467500008.340256 qam27
203547500008.340256 qam28
213627500008.540256 qam29
223707500008.540256 qam30
23378750000840256 qam31
243867500007.940256 qam32
1Locked40.3220
2Locked40.380
3Locked40.9190
4Locked40.9200
5Locked40.3120
6Locked40.3160
7Locked40.3150
8Locked40.3130
9Locked40.9220
10Locked40.9220
11Locked40.3130
12Locked40.3200
13Locked40.9140
14Locked40.3170
15Locked40.370
16Locked40.3170
17Locked40.3180
18Locked40.3310
19Locked40.3260
20Locked40.9140
21Locked40.3170
22Locked40.3140
23Locked40.9280
24Locked40.3160
Upstream
13259999340.5512064 qam5
23939998840.5512064 qam4
34620000942512064 qam3
45370000042512064 qam2
1ATDMA0040
3ATDMA0010
4ATDMA0010
10/02/2022 16:23:13noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2022 16:23:0Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2022 16:22:39noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2022 16:22:19Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/02/2022 16:22:4noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/02/2022 17:19:13criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/02/2022 07:52:27Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 17:07:12criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 12:49:27noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
08/02/2022 12:48:17Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/02/2022 17:37:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/02/2022 15:09:22noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
07/02/2022 15:09:22ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
04/02/2022 03:51:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/02/2022 23:36:22noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/02/2022 23:36:22ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2022 20:31:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2022 11:36:22noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2022 11:36:22ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
30/01/2022 05:16:32criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Doest look too bad. Down powers are on the high side but still well in range - no PostRs errors - which is good - a few T3's is not good - but these may be historical. accumulation. So can you do the below. Post up the link to the "live graph" BQM as soon as - it takes ~24h to see the full picture - but an early peek is good.
Someone else needs to comment on the logs.
_______________________________________________________________________
Switch the Hub off and unplug it from the mains supply for five minutes. Whilst it's off, do a quick check that all of your coax cable connections are in nice and "finger" tight - at the Hub and wall box and also at any connectors etc. Ensure there are no “unterminated cable loose ends. Disconnect all the connections and reconnect to be sure. Also check that the internal wiring is ok with no kinking or chaffing, check that all looks good with the outside cabling and wall box (no “staples, etc.,) piercing the cables.. Then switch the Hub back on and leave ~5 minutes
When all done, check back in the settings and ensure that the RS error counts and T3 errors have all reset to 0. Then check every hour or so to see if they start reappearing - they shouldn't. The odd T3 every daay or two is usually not to be bothered about. If they do "accumulate" (particularly the postRS and T3 ones) you have a problem (noise) that only a Tech visit will sort.
Hi @ForumUser102
How are you getting on after following the above suggestions?
Travis_M
