on 28-09-2021 09:41
Since recent TS11 area outage to upgrade signal drops for 1 - 2 secs every 5 or so mins. Rebooted and usual checks no difference.
WiFi perfect prior to outage
Answered! Go to Answer
on 30-09-2021 16:42
Hey @Kayem12,
Many thanks for your recent post. I'm sorry to hear of the issues you've been having with your WiFi in your home.
I've been able to locate your account using your forums details and have run some checks from our end - a signal issue has been flagged that a technician is required for.
I'd like to get a visit booked in for you so we can take a look into this and make sure everything is working as it should be.
I'll just send you a private message in order to do so, so please just keep an eye on the purple envelope at the top of the page.
Kind regards,
on 28-09-2021 09:54
are wired connections OK?
on 28-09-2021 13:50
Hard wired signal stable only WiFi giving problems
on 28-09-2021 14:45
on 28-09-2021 15:22
Hub4 have 2 boosters in other rooms. Using Amazon fire stick latest version. Issue is that had a good network prior to vm carrying out upgrade outage locally. Should I take this up with VM directly or is there a fix?
thank you for your reply
K
on 28-09-2021 15:25
on 28-09-2021 15:46
Ethernet connection to pc stable no issues.
thanks again
on 28-09-2021 15:47
on 30-09-2021 16:42
Hey @Kayem12,
Kind regards,
