on 12-09-2022 19:39
Hi is it possible to remotely turn off the WiFi as a parental thing
on 12-09-2022 20:09
Sure
to turn it back on you press button on the smart plug
on 12-09-2022 21:11
Bit difficult to do remotely. Some routers allow many SSIDs and you can then ‘turn off’ one remotely. VM hubs only allow minimum tailoring.
