on 18-06-2022 07:54
We have a Hub 5 and wifi connectivity is continually dropping and not reconnecting. Its happening on several devices including windows laptops, IOS and Android mobiles.
When VM offered to swap the Hub 3 for a Hub 5 they never stated that we would be part of a beta trial for a new product. No additional support was put in place.
To make matters worse, I’ve just received an email saying the price of my existing service is going up by 49% when our current contract ends in a few weeks.
I’ve read numerous other threads from people having similar issues. I’m not prepared to wait for firmware fixes that may or may not be rolled out in the future.
VM, if you want me to remain a customer, please replace my Hub 5 with a tried and tested older model. Otherwise I’ll be switching providers when my contract ends.
on 18-06-2022 15:23
on 19-06-2022 07:50
Thanks John
i stupidly returned the old hub 😱
i’m going to try calling the “I’m thinking of leaving line”
on 19-06-2022 09:52
The representative from them”Relationships” team said “I’ll cancel your service because I’m not prepared to replace your hub”. I asked for his full name to make a complaint and he refused to provide his surname or any other details.
Disgraceful customer service Virgin Media
19-06-2022 12:00 - edited 19-06-2022 12:04
Try the following, it may help ?
• Access your Hub by navigating to 192.168.0.1
• Login with the default login info (on base of Hub) unless you've already updated it.
• Go to Advanced Settings > Wireless > Security
• Under Wireless Frequency 2.4GHz change the Wifi Network Name (SSID), suggest append _2 to the end.
• Repeat for the Wireless Frequency 5GHz, suggest append _5 to the end and click on Apply changes
• Try to avoid spaces and periods in the SSID names as they can cause issues with certain devices.
• Disable the Smart Optimisation on the wifi bands.
Also set the 2.4Ghz wifi to legacy settings;
Go to Advanced Settings > Wireless > Wireless signal
In the Wireless frequency 2.4GHz select Wireless mode > 802.11b/g/n/ax mixed
Select Apply changes
As an aside, I have a Hub 5 in modem mode and runs a much improved BQM than my previous Hub 3, also in modem mode. However all the routing and wifi services are running off my own kit.
on 19-06-2022 13:10
If you have a MACBook you could also run the network diagnostics "scan" function which will recommend channels for the 2.4 and 5.0 network. Also run the "performance" function and note the noise levels.
Just a thought, might give you some insight into what is occurring.
Bill
