on 15-10-2021 14:25
So we have had virgin media for a year or so and I have always been getting packet loss, we have had people come round to try sort it and it still doesn’t work. My ethernet cable that connects to my pc is fine and i have tried multiple different ones. The wifi connection to my phone is also very poor, I am unable to use my wifi when face timing and using certain apps, as the wifi is too weak to use it. I am constantly having poor connection on both my phone and pc and it is getting worse. I am unable to play games on my pc due to it constantly lagging badly.
on 15-10-2021 14:47
on 16-10-2021 15:40
No other ethernet cables are connected to it, no. I get very bad lag; slow response time and constant packet loss. I try to play games but when I try to play games like fifa, my game freezes for about 30seconds - 1 minute and then i get speed up lag. Which It does multiple times a game, so it’s pretty much unplayable. The wifi on my phone can be very week sometimes and every time I try to facetime someone on my iphone I disconnect and lose connection because of “poor connection” so I have to use my 4g. I’m not sure on the model itself but the speed of the model, I believe should be between 200-300.
on 16-10-2021 16:15
on 17-10-2021 21:11
latency 15.8 ms
jitter 3.57 ms
download 61.7 Mbps
upload 36.2 Mbp
on 18-10-2021 15:38
on 20-10-2021 15:48
Hi Jacobbarwick, thanks for posting.
Sorry to hear about the problems you've had with WiFi. If the WiFi tips here (virg.in/WiFiwins) don't help then you may be eligible for WiFi Pods (more in this here: https://www.virginmedia.com/shop/broadband/intelligent-wifi-pods-new)
We'll be able to check for any issues with the connection/hub if you can post the info requested by jbrennand above. I wasn't able to check things over from our side using your forum info alone on this occasion, if you get back to me via PM we'll be able to take a closer look into it.
Tom
