on 30-08-2021 15:33
I have M200 fibre broadband package and until two weeks ago the WiFi worked fine in all rooms in the house. It is a small house. Now I get very slow connectivity everywhere except the room the hub is in. This is making working from home extremely difficult. TEAMs meetings are impossible.
Using the Virgin connect app it shows good WiFi coverage everywhere but when I log in to the hub settings and go to network diagnostics it says your net work has a few problems and recommends moving devices closer to the hub.
Virgin were doing some work in this area (Cambridge) a couple of weeks ago and it seems too much of a coincidence that now I have great difficulty getting enough signal to work.
Does anyone one have any suggestions?
on 30-08-2021 15:53
on 30-08-2021 16:02
on 30-08-2021 17:09
Hi john
ethernet connection is fine. Hub is a hub3.0
on 30-08-2021 17:18
on 30-08-2021 17:35
Yes I would have to pay for the pods. I am a bit sceptical about them especially as the virgin connect app has scanned for WiFi black spots and can’t find any.
I will give the other stuff a try but am not very technical so might take me a while.
thanks for your suggestions
on 30-08-2021 17:36
on 30-08-2021 19:07
on 01-09-2021 19:35
Hi Spidie35,
Thank you for reaching back out to us in our community and welcome back, sorry to hear you have been facing a reduced connection recently, I have managed to locate your account with the details we have for you and have had a look at things our end, I couldn't see any issues at all, your levels are all as expected with no errors.
can you try a pin reset on the Router just to rule out a software issue, first check all the internal connections are hand tight then push a pin/ paper clip in the back of the Router where it says reset, push in until you feel it press then hold in for a timed 1 Minute, do not reboot during or after and allow 15 Minutes to settle afterwards?
Paul.
