on 06-06-2022 09:48
can not connect my hub3 on the virgin media connect app. My wifi is showing weak security also. Any advice on how I can fix this? As I need to change the settings on my hub but will not let me
connect the hub to the app to change settings
on 06-06-2022 14:47
on 08-06-2022 20:37
Hi Vinam,
Thank you for your post and welcome to the community.
I'm very sorry for any issues you've had with accessing the settings on your hub.
Have you been able to follow the advice provided by jbrennand? If so, has this been able to assist?
^Martin
