  • 9
ArtcyTracy
Message 21 of 23
Re: Wifi Security camera won't connect
Deleting this message as it was posted multiple times.
  • 2.78K
  • 139
  • 405
jpeg1
Trouble shooter
Message 22 of 23
To see the camera directly you will need to access the WAN IP assigned to your Hub by VM, and open the appropriate port/s in the Hub that are used by the camera. You'll also need a suitable app for your phone, and there are many apps available on the app stores. You may have to try one or two depending upon the video format of the camera.
  • 9
ArtcyTracy
Message 23 of 23
Thanks for this info. I would like to try out a few different apps. I will also try accessing it directly through my WAN.
