on 17-05-2021 15:51
Received a wifi pod with my ultimate Oomph package. It worked well for months, but has now stopped pairing. the light is constantly flashing. I have done everything suggested in the troubleshooting guide, all to no avail. Any other suggestions please? Thanks
on 17-05-2021 16:42
on 19-05-2021 15:57
Hi bltnotts,
Thanks for posting. Apologies for the Pod issue.
Please see this guide here which should help fix this 🙂
Kind regards,
on 23-05-2021 13:40
Thanks but I'd already exhausted everything that route. Plus it seems impossible to speak to anyone on the phone 😞
on 23-05-2021 15:18
From what you have advised it sounds like it isn't connected bitnotts, the light in the center of the Pod will pulse. To reset it, remove it from the socket and leave it out for 30 minutes, then plug it back in again and turn the power back on to the socket.
The light may then pulse for up to 10 minutes but then should connect. If not let us know and we'll look into this further.
Rob
on 28-05-2021 15:35
Done all that and still no joy 😞
on 28-05-2021 15:40
Hello bltnotts
Thanks for trying that
I am more than happy to take a look at this for you
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
on 31-05-2021 11:42
Hello bltnotts
Thanks for passing security
I have requested for a the faulty Pod to be swapped
A replacement Pod has been ordered
It can take around 5 days
But we do have a little delay due to stock levels right now
Gareth_L
on 31-05-2021 12:26
on 02-07-2021 15:16
Me again 😞 Received a replacement pod , worked fine for a couple of weeks but I now have the exact same problem.
