on 11-11-2021 14:11
How do i go about gettin my wifi pod attached to my new router? spent 40 mins on hold and gave up today.
been upgraded to the 4 from the 3 now cant get it to connect. any help appreciated
11-11-2021 14:28 - edited 11-11-2021 14:29
Try the new equipment activation line - see if they can help - 0800 953 9500 - option 3
on 11-11-2021 14:33
If it's anything like mine it should connect itself. When you plug it in the very small LED light should start pulsing slowly, and when its made the connection it should go out. This can all take some time, and the instructions that came with mine said that it can take up to 24hrs to completly settle down.
I assume that the pod is not too far from the router
on 11-11-2021 14:40
yeh worked with my hub 3.0. gave it a reboot when i got the 4.0 been under 24 hours now so il take a look tommoro
on 11-11-2021 14:49
on 11-11-2021 14:54
on 11-11-2021 16:17
Having the same issue, received my hub 4 today, all working, however the pods aren't. White light flashing, called VM and the need to be activated on the new hub, I was told that it should take 24 hours and someone would call me back. Not holding my breath, lets wait and see if they do.
11-11-2021 18:05 - edited 11-11-2021 18:06
I used the live chat... an hour and 30 mins in. i was told signals had been sent to the router and to reboot them both.
now have green pulse for a few mins then back to white pulse for about 5-10. Il have to see what happens in the next 24 hours
on 14-11-2021 13:34
Hi wigelz,
Thank you for reaching back out to us, how are your Pods working Today, have the lights not gone off?
Paul.
on 19-11-2021 18:56
i can confirm this has now been fixed. Im lead to beleive settings need sending to your router and after 24-48 hours its sorted. i was away for 5 days so wasnt able to confirm the time it took.
all good now though
