on 16-01-2022 18:15
Whats going on no wifi Perth centre
drops out last 2/3 days
come on ‼️
on 16-01-2022 18:25
Are you asking about a public WiFi service? Or that you live in Perth, and have problems with your home broadband? If the latter, do wired connections work ok?
on 16-01-2022 18:25
@completecontrol wrote:Whats going on no wifi Perth centre
come on ‼️
Wifi is prone to dropping out. Does a wired connection work?
on 17-01-2022 06:57
Home Broadband
on 17-01-2022 08:05
Is you Ethernet dropping out to - Wifi is local to you own house? If Ethernet is stable then the problem will be there.
come on ‼️
on 19-01-2022 13:31
Hello completecontrol
Sorry to hear of the broadband issues experienced, we appreciate you taking the time to raise this via the forums and welcome to the community.
From looking at your connection and equipment there does appear to be some issues with the power levels across some of your downstream channels which will require a technician. I will send you a Private Message to get some more details from you to arrange this.
Rob
on 19-01-2022 14:05
on 21-01-2022 15:54
Thanks for coming back to us @completecontrol.
I cant see that a PM has been sent over to you, I have just dropped one over to you now. Please look out for it and we can get started.
Regards,
Steven_L
