on 21-02-2022 17:12
Are wifi pods still not available?
I have the ultimate oomph package and currently have a Hub 3 plus a wifi booster to extend signal to my study. I am unable to get wifi in the bedrooms at the other end of the bungalow however. Today I went through the room scan process and for the bedrooms it tried to update the chip to improve wifi signal but the end result was a message saying that failed and I need a pod for that room. However on trying to order it says they are not available and I have to sign up for marketing to enable me to get an email when they become available. Whilst I have, reluctantly, done this I am not happy at the prospect of being bombarded with text and phone marketing calls just because I want to order something that should be freely available within my package.
[MOD EDIT: Post split to create own thread]
Answered! Go to Answer
on 01-03-2022 12:16
Hello countyexile
Tom advised we can order up to 3 pods for you
Just only 1 at at time
Are you still looking to go ahead with this
If so, please let us know
Gareth_L
on 21-02-2022 17:24
on 22-02-2022 13:31
Thanks for that and for the advice. I'll wait to see if they contact me after posting on here and signing up for email notice of availability.
They do seem to try to make contacting them for even simple matters far from straightforward! These pods were announced in a blaze of publicity, they provided an app so room checks and signal levels can be tested, yet when you go through the process and they say you need a pod you can't get one unless you jump through a series of further hoops.
As mentioned in my original post I have the ultimate oomph package, I went through the full process of the room checks and attempts to upgrade the chip to improve wifi coverage which came to the conclusion a pod was needed, so don't understand why they can't simply send one after those tests have been properly carried out.
on 22-02-2022 14:41
Hello @countryexile,
Welcome back, thanks for posting.
I am sorry for inconvenience caused with this.
Can you please tell me if you are able to see an order for this on your account?
Many thanks,
on 22-02-2022 15:35
Hi Hayley,
I have just logged into my account and under the "My Orders and appointments" section it says "It looks like you don't have any open orders"
Rob Fudge
on 26-02-2022 13:39
Hi @countyexile, thanks for your reply and apologies - if that's the case it doesn't seem like there'll be any wifi pod on its way to you.
If you do have the old wifi booster kit which it sounds like you do, please note that we cannot run these alongside our Intelligent Wifi Pods.
I'm more than happy to help place an order for you and if so, I'll pop you a PM but firstly please let me know if you're happy for me to do this bearing in mind that it will deactivate your current wifi booster kit (only from when you activate your pod though).
We can only order one wifi pod at a time unfortunately, but t's important to note that you can have up to 3 wifi pods so in the long run, the pods may be a better solution.
Many thanks
on 27-02-2022 12:10
Hi, Thanks for your reply.
If only one pod can be ordered and it would deactivate the wifi booster there doesn't seem to be much point in ordering one at this stage as I would require 2 to provide the coverage needed.
Due to the layout of my bungalow, irrespective of where the hub is located, there are at least two wifi weak spots - one in my study, where the booster is currently located, and one in the area where the bedrooms are located. To replace the booster with a single pod in the study would just leave the same situation as it is now and still no coverage in parts of the bungalow.
If additional pods can't be ordered within the Ultimate Oomph package I am signed up to would a 2nd one be available for a one off cost please? When you say I can have up to 3 wifi pods are you saying this is something I can't order now but will become available in the future?
Rob
on 01-03-2022 12:16
Hello countyexile
Gareth_L
on 01-03-2022 12:27
Hi Gareth,
Yes please I would like to go ahead ordering the first one now if it means I can apply for a 2nd at a later date.
Rob
on 03-03-2022 12:33
Hello @countyexile,
Thanks for coming back to us.
I will send you a private message now, please look out for a purple envelope.
Many thanks,
