on 18-04-2023 12:39
Hi, I have been having issues with my wifi dropping out for quite a while now. Most evenings after 8pm my tablet and my wifes ipad experience frequent dropping of the internet. Restarting the tablets or restarting the hub sorts it for a while but it still happens. Its not the tablets because these are new and it also happened on the previous ones. I have run the service status as suggested on the Virgin Media site and the issue is still there. I am not tech savvy and need help or suggestions. Thanks
on 18-04-2023 13:21
on 18-04-2023 15:37
Hi, My PC is connected by cable and does not drop connection when the tablets do.
on 18-04-2023 15:44
on 20-04-2023 16:51
Hi, thanks. I have changed the SSID to your suggestion. Obviously I now have 2 wifi settings to choose from, just wondering how this will help and which one do I connect to? Sorry to sound confused.
on 22-04-2023 17:30
Hi Peelde,
Thank you for getting in touch with our Community.
When splitting the SSID's, you will have the 2.4Ghz and 5Ghz connections available.
5Ghz is suitable for devices in close range of the Hub.
2.4Ghz would be devices that are not in the same room/area as the Hub.
Both options will be available when searching WiFi connections so please select the option that best suits your device.
on 22-04-2023 17:37
Thanks for that. So far splitting seems to be working, no had many disconnections since doing it. Will keep my eye on it though.
