  • 5
AIB
Message 1 of 11
Wifi Boosters
I have been supplied two boosters which I have paired with the hub and strategically placed around the home. Sadly my wireless download speed has not improved and is hovering around 13Mbps although I have noticed a slight improvement in upload speed from 6.0Mbps - 9.2Mbps. In order to get the 100Mbps expected would I need to plug an ethernet cable into the booster or should I be getting better download speeds wirelessly?
Many thanks
Andrew
  • 1.29K
  • 177
  • 539
Andruser
Knows their stuff
Message 2 of 11
Re: Wifi Boosters
The theoretical speeds over wifi are very fast - 2.4 GHz wifi is slower than 5 GHz, but even 2.4 GHz can (in theory) offer 300 Mbps.  Here in the real world speeds are invariably much lower, but even so, you should be able to get a 60 Mbps wifi connection over 2.4 GHz, and 90 or a lot more on 5 GHz.
So your 6-9-13 Mbps is rather pitiful, and suggests that you have either got a booster problem, or a wifi environment problem.  We can help you out, but we'll need a bit more detail on the property size, shape, age, what hub you've got, whether you've done stuff like rename the 2.4 and 5 Ghz channels, what speed you see on a wired connection from a PC or Mac connected to the hub by a network cable, what devices are reporting these wifi speeds, and things like this.
  • 5
AIB
Message 3 of 11
Re: Wifi Boosters
Hello
Please forgive me, I am not sure I understood the response? - I have not renamed any channels and would not know how.
I have the hub that was delivered and have installed two boosters - I was told by the engineer that his would improve my download speeds - sadly I am not seeing it.
I do not have an ethernet cable able to reach the point that he booster is plugged in. My PC is in the study on the first floor of a four bedroom detached property. The property is fairly modern the hub is in the living room on the ground floor and both boosters are installed on the first floor.
I cannot get to the plug socket in my study as it is in a corner behind my very large desk with no direct access.
Not sure that helps. I was however hoping for a better experience. The boosters are working correctly as detailed in the booklet.
Best wishes
Andrew
  • 2.52K
  • 97
  • 175
Message 4 of 11
Re: Wifi Boosters
Hi AIB,
Thanks for posting and welcome to the community 🙂
My apologies for the low speeds, what devices are you testing on please?
Kind regards,
John_GS
  • 5
AIB
Message 5 of 11
Re: Wifi Boosters
Hello
Thank you for the reply
I am testing on my desktop PC - using a wifi signal.
Many thanks
Andrew
  • 1.31K
  • 73
  • 93
Message 6 of 11
Re: Wifi Boosters
Thanks AIB,
Can you confirm how the speeds are when testing a wired connection from the hub to your device?
Is it just the WiFi/ boosters you're having the issue with?
When was the last time the hub was rebooted?
Alex_Rm
  • 5
AIB
Message 7 of 11
Re: Wifi Boosters
The Hub is brand new only installed a week ago - I would not know how to reboot it.
I do not have an ethernet cable long enough to extend from the booster to my device in the study - so just the wifi speed at this time.
Many thanks
Andrew
  • 1.31K
  • 73
  • 93
Message 8 of 11
Re: Wifi Boosters
Are you able to connect an Ethernet cable from your hub direct to your laptop to test your speeds without using the boosters?
Alex_Rm
  • 5
AIB
Message 9 of 11
Re: Wifi Boosters
An ethernet cable directly from the hub into the notebook gives a download speed of 102.3 Mbps
Wireless speed at my desktop PC in the Study with no direct connectivity through two boosters is 31.0 Mbps - This speed is not constant - it has been as low as 9.7Mbps and as high  as 49.5 Mbps wireless depending on time of day. - This is really not what I had hoped for.
The study  is where I need the speed but do not want to trail a cable across the house to get the speed I want
When I connect the notebook to the ethernet point on the booster I get 45Mbps- this is still only half of what I was expecting.
Something must be wrong?
Any help is appreciated
Best wishes
Andrew
  • 2.52K
  • 97
  • 175
Message 10 of 11
Re: Wifi Boosters
Hi AIB,
Can you turn the hub off/on again and then run a wired test at speedtest.net with only the one device connected to the internet? Then the same with the wireless test.
Kind regards,
John_GS
