on 02-11-2021 20:22
Hi there for the last week or two I’ve had constant problems with my internet with it stopping working sometimes , and times the speed drops to as low as 5mbps when I’m on 350mbps plan , the signal doesn’t reach my bedroom properly as-well most of the time , where I can’t watch videos or scroll social media without having to use mobile data , I’m also a keen gamer and for the last week it’s been unplayable where the game just sticks and I can’t move etc , Then when I reset the router with the pin at the back it seems to make it work ok for a day then it goes back to the same problems and I have to reset it again , was just wondering if there was any answers to this thanks ……(p.s I asked these questions on Twitter and they sent me here saying it sounds like a WiFi issue rather than a problem with the external network )
on 06-11-2021 20:46
I’ve moved into a new house and the previous tenants had virgin and they have the boxes coming through the ceiling from the loft so the main wall box must be in the loft that I don’t actually have a ladder to access at the moment so I can’t check those wires and box up there at the moment which is annoying , but what you are saying with the channels etc is there is definitely a problem with things
on 06-11-2021 21:09
on 07-11-2021 09:47
No the hub is in my living room but the little box that you connect the hub and the virgin tv box into is on a wire that leads into the loft , I will turn the router off and leave it for 5/10 mins soon when I get In from work and send the data again
on 07-11-2021 11:31
Acquired Downstream Channel (Hz) | 139000000 | Locked |
Ranged Upstream Channel (Hz) | 46200283 | Locked |
Provisioning State | Online |
on 07-11-2021 11:31
1 | 139000000 | -6 | 38 | 256 qam | 1 |
2 | 147000000 | -5.7 | 38 | 256 qam | 2 |
3 | 155000000 | -5.5 | 38 | 256 qam | 3 |
4 | 163000000 | -5.4 | 38 | 256 qam | 4 |
5 | 171000000 | -5.2 | 38 | 256 qam | 5 |
6 | 179000000 | -5.2 | 38 | 256 qam | 6 |
7 | 187000000 | -5.2 | 38 | 256 qam | 7 |
8 | 195000000 | -5.2 | 40 | 256 qam | 8 |
9 | 203000000 | -5 | 38 | 256 qam | 9 |
10 | 211000000 | -5 | 38 | 256 qam | 10 |
11 | 219000000 | -5.2 | 40 | 256 qam | 11 |
12 | 227000000 | -5.2 | 38 | 256 qam | 12 |
13 | 235000000 | -5.4 | 38 | 256 qam | 13 |
14 | 243000000 | -6 | 38 | 256 qam | 14 |
15 | 251000000 | -5.7 | 38 | 256 qam | 15 |
16 | 259000000 | -4.9 | 38 | 256 qam | 16 |
17 | 267000000 | -4.7 | 38 | 256 qam | 17 |
18 | 275000000 | -4.7 | 38 | 256 qam | 18 |
19 | 283000000 | -4.7 | 38 | 256 qam | 19 |
20 | 291000000 | -4.7 | 38 | 256 qam | 20 |
21 | 299000000 | -4.5 | 38 | 256 qam | 21 |
22 | 307000000 | -4.7 | 40 | 256 qam | 22 |
23 | 315000000 | -5 | 38 | 256 qam | 23 |
24 | 323000000 | -5 | 38 | 256 qam | 24 |
1 | Locked | 38.9 | 302390 | 120694 |
2 | Locked | 38.6 | 21952 | 0 |
3 | Locked | 38.9 | 6124 | 0 |
4 | Locked | 38.9 | 5467 | 0 |
5 | Locked | 38.9 | 4096 | 0 |
6 | Locked | 38.9 | 2738 | 0 |
7 | Locked | 38.6 | 2296 | 0 |
8 | Locked | 40.3 | 1133 | 0 |
9 | Locked | 38.9 | 1116 | 0 |
10 | Locked | 38.9 | 1211 | 0 |
11 | Locked | 40.3 | 774 | 0 |
12 | Locked | 38.9 | 722 | 0 |
13 | Locked | 38.9 | 556 | 0 |
14 | Locked | 38.9 | 503 | 0 |
15 | Locked | 38.9 | 304 | 0 |
16 | Locked | 38.9 | 74 | 0 |
17 | Locked | 38.9 | 49 | 0 |
18 | Locked | 38.9 | 26 | 0 |
19 | Locked | 38.9 | 20 | 0 |
20 | Locked | 38.9 | 9 | 0 |
21 | Locked | 38.9 | 6 | 0 |
22 | Locked | 40.3 | 7 | 0 |
23 | Locked | 38.9 | 5 | 0 |
24 | Locked | 38.9 | 4 | 0 |
on 07-11-2021 11:32
1 | 46200283 | 57 | 5120 | 64 qam | 3 |
1 | ATDMA | 0 | 0 | 1 | 0 |
on 07-11-2021 11:33
07/11/2021 11:22:18 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/11/2021 11:03:4 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
07/11/2021 09:41:30 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 14:43:42 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/11/2021 17:25:35 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/11/2021 11:24:36 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/11/2021 05:20:9 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
04/11/2021 00:56:35 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/11/2021 14:22:26 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
03/11/2021 05:15:26 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/11/2021 00:18:37 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/11/2021 17:44:45 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/11/2021 17:44:21 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/11/2021 17:44:21 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/11/2021 16:50:34 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/11/2021 16:50:34 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/11/2021 16:42:32 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/11/2021 16:42:8 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/11/2021 16:41:44 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/11/2021 13:56:9 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 07-11-2021 14:27
on 07-11-2021 14:39
Hi @Div7
Thanks for posting and welcome to the community. My apologies for the broadband issues.
I can see from a system check that you should have 4 upstream channels and only one is showing. That level as well is out of spec. As are a few of your downstream channels.
This all means a technician visit to the property is needed. I shall send you a PM now to get some details.
Kind regards,
on 07-11-2021 15:54
Hi @Div7
Thanks for joining me on PM.
Just to update the thread, the engineer visit was booked in.
This can be tracked and/or altered in your online account
Let us know how the visit goes.
Best,
