on 10-09-2021 13:35
I Have just upgraded from 200Mbps to 350Mbps. I am getting speeds of no more than 90mbps, this affects wired and wireless connections
on 10-09-2021 13:36
on 10-09-2021 13:50
Hello Dunking
Thanks for popping over here
It was myself that relied to you on our Social Pages
So I can look at this in more detail
I would need to access your account
I will need to send you a private message to pass security
If you can check the purple envelope top right of your screen that would be great
Gareth_L
on 10-09-2021 13:58
It’s set to 100/100. Prior to upgrading, I was getting WiFi speed up to around 220mbps. I’ve done a factory reset on the hub, this resolved the issue for about 5 minutes, with speeds over 350, then simply dropped back down.
on 10-09-2021 14:01
