on 21-02-2022 20:55
Hi, I've had an issue with my router for over a week. My hub3 has a solid green WiFi light and a flashing green light. All of my devices can connect to the router but none of them can access the Internet. I've been in contact with customer support but none of the diagnostic tests they did over the phone led to anything, and all the connections to the router are fine. Customer support said they would refer my situation to an engineer almost a week ago but I have not heard anything. I am wondering if this is a problem which I can fix myself because I assume I won't hear from an engineer at this stage. Has anyone had a similar problem/been able to fix it themselves? Will I need a new router?
Thanks!
P.s. on the first page of the router settings, it says that the connection is ok on both 2.4 Ghz and 5 Ghz channels but there is no Internet.
on 22-02-2022 14:40
on 23-02-2022 18:28
Thanks for your reply. Yes I did check that. I am certain the fault is with the router not connecting to the Internet, not a local issue.
on 23-02-2022 22:22
Problems like this are usually circuit problems rather than hub problems. With the symptoms you describe it’s very rare for it to be a hub problem. The local area fault phone as given my John is your best bet.
on 26-02-2022 14:22
Hi @djones34, thanks for your post although I'm really sorry that you're still having problems with your network.
I'm going to pop you a PM to ask you to confirm some details, just so I can get a technician booked for you.
In the meantime though, please also try a factory reset of your Hub just in case this resolves the problem.
Either way though please expect this PM and respond when you can!
Many thanks
on 28-02-2022 15:30
Hi @djones34, thanks for your reply via PM.
I can see that it appears you manged to arrange a technician so I don't need to book this for you - you can manage your appointment via your My Virgin Media app.
I hope this helps and please let me know if you need any further assistance!
Many thanks
