Hi Winchelsea,
Thanks for taking the time to come back to us in the Community.
We're sorry to hear this is the case. More often than not, the pod will need to be reconfigured at this end to be linked with your new hub. I've checked things today and can see the teams have already sent you a replacement so this should automatically connect to the hub for you.
I'd like to offer some further help with the WiFi connection as there are so many things that can influence it, some of which include but are not limited to, a fish tank being in the same room, walls being built with concrete instead of brick, it could even be that your next door neighbours router is interfering with yours. Due to this, we are only able to offer limited help. Please have a look here: WiFi Help.
The Hub's location could also be causing the coverage problem so we do need to check the positioning of it. Can you please ensure the following:
- Out in the open
- Next to the TV not behind it
- Away from large bodies of water (e.g. fish tanks)
- Away from baby monitors and cordless phones
- Think of the Hub as a radio, and WiFi as the sound - the further away you are from the radio, or the more obstacles that are in the way (walls, electronic devices etc.), the quieter the radio & the poorer the WiFi.
If that doesn't help, you can download our Connect App which will allow you to scan areas of your home and will offer help. You can view more information on that here.
Please keep us posted on how you get on.
