on 19-01-2022 21:49
I have a hub 3 and have always had a separate name for the 5Ghz and 2.4Ghz signals.
Yesterday I added a second intelligent WiFi Pod to my house and ever since then the hub keeps renaming the 5Ghz to the same name as the 2.4Ghz.
I have logged into my router several times and changed it back but give it a few minutes and the name of the 5Ghz disappears.
Is there any reason why this is happening because I like to keep the 2 separate.
on 19-01-2022 22:01
I believe that for the pods to work (and these are the VM WiFi pods, I assume) that all of the ‘intelligent’ WiFi settings need to be enabled on the Hub, and this includes NOT having a separate name for the 2.4 and 5 GHz bands, auto channel selection etc.
This isn’t negotiable, I’m afraid, if you want to keep using the pods then it has to be this way.
on 19-01-2022 23:05
I had a feeling it was something to do with the pods.
