  • 7
Grayball9
WiFi issues
Anyone tell me why this is all I’m getting when I pay for 500mbps?
  • 7
Grayball9
Re: WiFi issues
Not sure if the picture is coming up, but the download speed is 46 and upload 5!
Any Help appreciated
  • 26.85K
  • 1.16K
  • 4.52K
Re: WiFi issues
that is wireless though what speed do you get wired with a gigabit connection
Click to learn more about VIP
Use Kudos to say thanks
  • 2.32K
  • 144
  • 597
cje85
Problem sorter
Re: WiFi issues
You're probably using the 2Ghz network that will only reach about 40-60Mbps, instead of 5Ghz. By default they both have the same name. You need to log in to the hub and give them different names (for example add -2G and -5G to the end) then reconnect your phone to the 5G network.
  • 7
Grayball9
Re: WiFi issues
How do I do that? I’m beginning to feel old now!
  • 13
AndyWhite20
Re: WiFi issues
Mine has been terrible since yesterday also. I've done what's suggested above an no difference. So I understand your frustration.
