  • 6
xxdd91
WiFi is driving me mad...
Hi all
Ive been with VM approx a month and I’ve already had a engineer out twice. I’m going to keep this short...
In two rooms of my house I’m getting 200mb WiFi. In every other room between 0-40mb.
When the engineer came out the 2nd time he offered me three solutions
1. Move my router / this could potentially cut other rooms off?
2. Buy powerlines that support WiFi / move one outside the the two room range and hope it’s better
3. Buy a better router and run modem mode
I feel some of my options here are all a bit hopeful I could potentially do them all and get nowhere...
Has anyone got any recommendations on what they’d try first I’m assuming powerlines might be an easy options as I could return them if there not suitable?
Moving the router I’m not overly keen on and buying a new router would be harder to do return as I’d likely have to buy this online...
Help
  • 10.34K
  • 647
  • 1.36K
jb66
Re: WiFi is driving me mad...
Try the virgin powerlines.  Its £3 per month but you cancel them anytime.
  • 12.95K
  • 989
  • 2.98K
last point - buy from amazon - easy to return - will increase coverage and may help speeds
powerlines will help if they work - old wiring and split circuits can be a problem - try and see as you have concluded is the best option
on the hub3 have you split the broadband channels and turned off smart wifi - that should help
as to speeds at distances from the hub3 are the low speeds being tested on the same device as the 200 near the hub - not all devices will get the same speed
and finally [for now] does the low speed at distances from the hub actually matter or are you just wanting to see the same high speed all over the house - if things are loading and working then its of no consequence other than you know the speed
____________________
Tony
  • 6
xxdd91
Thanks Jb66 do I just order them via my account?
  • 6
xxdd91
My house was re-wired 5 years back so I’d hope it was okay.
same device used for all tests iPhone&laptop
ive split it into two channels it didn’t really improve much
I don’t need the speed in all of the rooms but some I do or at least a better speed that 0-40 as it’s drops out and bounces a lot
  • 10.34K
  • 647
  • 1.36K
jb66
Technicians have them or they can be posted out, the ones virgin provide are the best I've seen.  Bit of a faff setting up but once working are good
