Lucky30
Message 1 of 8
WiFi extension
Hi we have recently joined Virgin and have a secondV6 box in our garden room. We also ran a cat6 Ethernet cable out to our garden room when it was built. We now want to get WiFi out there as the signal from the hub in the house doesn’t reach down the garden. Can anyone tell me how I do this?
  • 18.81K
  • 1.64K
  • 4.11K
Message 2 of 8
Re: WiFi extension
you could attach a wireless access point to the end of Cat6 cable, there is so many different makes/model of access points depends on budget.. a lot of the community recommend using ubiquiti hardware, could get something like https://www.amazon.co.uk/TP-LINK-Archer-C50-V3-AC1200/dp/B075PDLQ2Y/ref=sr_1_1_sspa?s=computers&ie=U... this is a router but have option for access point.
Lucky30
Message 3 of 8
Re: WiFi extension
Would an old sky router work?
  • 410
  • 19
  • 83
tonycv51
Fibre optic
Message 4 of 8
Re: WiFi extension
Looks like it would on this sky forum post by ticking some individual settings as doesn’t look like it has a simple “access point mode”
the post does describe it but you’ll need a laptop connected directly to the Sky router to set it up.  Once done then connect sky router to the wired lan point in the room.  You’ll need to decide whether to use a separate WiFi network name so that you can choose to connect to that from your phones and tablets, or whether to use the same WiFi network name and hope you get good seamless roaming between the two
https://helpforum.sky.com/t5/Broadband/Using-2nd-Sky-Q-Hub-as-access-point/td-p/2845054
Lucky30
Message 5 of 8
Re: WiFi extension
We didn’t have Sky Q so not sure if our old router would be suitable?  we also have an old Netgear Rangemax next router that has been given to us.
Other forums suggest that Adsl routers don’t Work with virgin ?
  • 18.81K
  • 1.64K
  • 4.11K
Message 6 of 8
Re: WiFi extension
adsl routers are designed to work with e.g. BT/talktalk,Sky broadband since virginmedia works via cable totally different network.. looking briefly at the Netgear Rangemax next that is a wireless access point so should work fine.
  • 410
  • 19
  • 83
tonycv51
Fibre optic
Message 7 of 8
Re: WiFi extension
Think setup to change it to an access point would be roughly the same on any recentish Sky router
The Netgear should have a specific access point mode link here
Dont worry about the adsl / virgin thing  the VM hub is doing the virgin connection and your overall home network. You’re using another “router” not as a router but as an access point onto the VM Hub network thanks to the cat6 cabling you put in
  • 1.17K
  • 46
  • 248
MrHalfAsleep
Knows their stuff
Message 8 of 8
Re: WiFi extension
Have a look at this thread: https://community.virginmedia.com/t5/Forum-Archive/Using-a-Router-to-extend-wifi-network/m-p/3240336...
The only winning move is not to play.
No system is 100% secure
Ridicule is nothing to be scared of - Adam Ant
The only thing constant - is change. Chris Evans
The internet is a series of tubes
Windows Update isn't rocket science - if it were, it would work.
Unlike Monty Python, spam is never off.
