on 21-09-2021 14:24
I recently switched to using my hub in modem mode with an external router, and have been experiencing constant drops in connection.
The network log shows a steady stream of errors each day. Today's is below...
21/09/2021 13:09:5 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 13:08:55 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 13:08:28 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 13:08:28 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 13:07:14 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 13:07:14 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 13:06:36 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 13:06:36 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 13:01:29 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 13:01:6 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 13:01:2 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 12:59:4 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 12:58:30 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 12:58:30 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 12:43:34 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 12:43:33 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 12:43:22 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 12:43:19 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 12:35:11 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/09/2021 12:34:58 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 21-09-2021 14:50
on 21-09-2021 15:00
on 21-09-2021 15:07
Thanks for the reply, downstream and upstream are below...
Channel | Frequency (Hz) | Power (dBmV) | SNR (dB) | Modulation | Channel ID |
1 | 299000000 | 12.4 | 38 | 256 qam | 21 |
2 | 235000000 | 11.6 | 38 | 256 qam | 13 |
3 | 243000000 | 11.5 | 38 | 256 qam | 14 |
4 | 251000000 | 11.6 | 40 | 256 qam | 15 |
5 | 259000000 | 11.9 | 40 | 256 qam | 16 |
6 | 267000000 | 12.1 | 40 | 256 qam | 17 |
7 | 275000000 | 12.5 | 40 | 256 qam | 18 |
8 | 283000000 | 12.5 | 40 | 256 qam | 19 |
9 | 291000000 | 12 | 38 | 256 qam | 20 |
10 | 307000000 | 12.6 | 40 | 256 qam | 22 |
11 | 315000000 | 12.5 | 38 | 256 qam | 23 |
12 | 323000000 | 12 | 38 | 256 qam | 24 |
13 | 331000000 | 12.1 | 38 | 256 qam | 25 |
14 | 339000000 | 12.9 | 38 | 256 qam | 26 |
15 | 347000000 | 12.6 | 40 | 256 qam | 27 |
16 | 355000000 | 12.3 | 38 | 256 qam | 28 |
17 | 363000000 | 12.5 | 38 | 256 qam | 29 |
18 | 371000000 | 12.5 | 38 | 256 qam | 30 |
19 | 379000000 | 12.3 | 38 | 256 qam | 31 |
20 | 387000000 | 12.1 | 38 | 256 qam | 32 |
21 | 395000000 | 12.8 | 38 | 256 qam | 34 |
22 | 403000000 | 12.9 | 38 | 256 qam | 35 |
23 | 411000000 | 12.4 | 38 | 256 qam | 36 |
24 | 419000000 | 12.1 | 38 | 256 qam | 37 |
Channel | Locked Status | RxMER (dB) | Pre RS Errors | Post RS Errors |
1 | Locked | 38.9 | 437097 | 172605 |
2 | Locked | 38.9 | 1121588 | 295899 |
3 | Locked | 38.9 | 1008003 | 275058 |
4 | Locked | 40.3 | 899295 | 251279 |
5 | Locked | 40.3 | 753501 | 239727 |
6 | Locked | 40.3 | 624244 | 221870 |
7 | Locked | 40.3 | 529928 | 203887 |
8 | Locked | 40.3 | 485697 | 181190 |
9 | Locked | 38.6 | 459499 | 176235 |
10 | Locked | 40.3 | 390362 | 162569 |
11 | Locked | 38.9 | 363167 | 144284 |
12 | Locked | 38.9 | 334587 | 137435 |
13 | Locked | 38.9 | 299673 | 129407 |
14 | Locked | 38.9 | 269394 | 114154 |
15 | Locked | 40.3 | 240540 | 105429 |
16 | Locked | 38.9 | 226282 | 100892 |
17 | Locked | 38.9 | 214940 | 99661 |
18 | Locked | 38.9 | 197974 | 94083 |
19 | Locked | 38.9 | 184339 | 83161 |
20 | Locked | 38.9 | 171548 | 77727 |
21 | Locked | 38.9 | 157489 | 73413 |
22 | Locked | 38.9 | 149595 | 68780 |
23 | Locked | 38.9 | 145641 | 65894 |
24 | Locked | 38.9 | 134848 | 59986 |
Channel | Frequency (Hz) | Power (dBmV) | Symbol Rate (ksps) | Modulation | Channel ID |
1 | 32600097 | 51 | 5120 | 64 qam | 11 |
2 | 39400000 | 47.8 | 5120 | 64 qam | 10 |
3 | 46199992 | 48 | 5120 | 64 qam | 9 |
4 | 25800000 | 51 | 5120 | 64 qam | 12 |
Channel | Channel Type | T1 Timeouts | T2 Timeouts | T3 Timeouts | T4 Timeouts |
1 | ATDMA | 0 | 0 | 3 | 0 |
2 | ATDMA | 0 | 0 | 6 | 0 |
3 | ATDMA | 0 | 0 | 6 | 0 |
4 | ATDMA | 0 | 0 | 6 | 0 |
on 21-09-2021 15:11
on 21-09-2021 15:16
on 21-09-2021 15:53
Hi @Mtc10
You do indeed need a tech as all downstream are out of spec.
Will send you a PM now to assist
Best,
on 22-09-2021 08:29
Hi Mtc10
Thanks for joining me on PM.
Just to confirm, the engineer visit was booked in.
This can be tracked and/or altered in your online account
Let us know how the visit goes.
Best,
