Ben4w
WiFi deadspots
Hi, I have WiFi deadspots at points furthest away from my router.  In both of the deadspots I have ethernet cables connected back to the router via a netgear switch, and have computers using each of the ethernet points. I would also like to be able to use WiFi in these rooms.  I have been thinking of getting the BT Whole Home system to address this issue but not sure if there’s an easier solution working off the ethernet points? (As you can tell from this post, I wasn’t involved in setting this system up...!). Any advice much appreciated.
  • 6.15K
  • 470
  • 1.02K
Hero
Re: WiFi deadspots
Easiest solution would be a Wireless Access Point. The Ubiquiti ones I use also have one Ethernet port so would be very easy to wire up in your situation.
