on 17-01-2022 12:35
Ive been working from my work laptop in the kitchen (about 5 steps from where the hub is situated) for about 2 years years w/o any issues.
Since last week, my WiFi connection keeps dropping out. This includes my TV that is situated in the same room as the hub. I spoke with a technician whim advised I need to pay an extra £5 p/m to boost the signal, even though my TV is in the same room as the hub!!!
I need this issue to be resolved ASAP as it's now affecting me wfh
Answered! Go to Answer
on 17-01-2022 15:59
Hi Dave
Thanks for your reply, I'll try that. Seems odd this issue has only happened since last week.
Even more frustratingly, none of your suggestions was mentioned during my call with one of your "technicians" who kept repeating me to pay an extra £5 per month to fix the problem. So basically, if your suggestion works, I would have been tied in to pay extra per month?!
Lee
on 17-01-2022 13:46
Hi @lansell82
It might be that a neighbour is sharing the same WiFi channel as yourself and thus impacting on your WiFi signal strength.
Have you separated the SSID's in your hub to differentiate between 2.4G and 5G.
The following details how to separate the 2 bands if you haven't already done so:-
Open a browser and log into your hub 192.168.0.1 (192.168.100.1 if using a 3rd party router) - then navigate to the following settings so you can differentiate between the signals.
Advanced Settings > Wireless > Wireless Signal > click on Disable Channel Optimization at the bottom then click on Apply Changes.
Now go to Advanced Settings > Wireless > Security > add a 5 to the 5 GHz Channel name and click on Apply Changes.
You can leave the passwords the same as they are. Then log out of the hub at the top of the page
You will need to reconnect all you Wi-Fi devices some will want to connect to 5Ghz and some to 2.4GHz and some will connect to either.
You could also do a search for an app such as wifi analyzer which tells you the strength of the channel you are connected on, and also shows other channels so you can decide if you want to change the channel number on your hub
Advanced Settings > Wireless > Wireless Signal > beneath both the 5Ghz and 2.4GHz sections click on the manual button, and in the drop down box click on the channel number you want to change it to, then scroll down and click on Apply Changes.
on 17-01-2022 15:59
Hi Dave
Lee
on 17-01-2022 19:12
I've just tried to do this fix/you're suggestion but tot appears the Internet is down completely. I've reset the hub (which I I earlier too) and this time hasn't resolved the issue.
Can you arrange for someone to call me to troubleshoot or arrange for a technician to visit me to check my hub? My frustrations with Virgin Media are increasing and will have no choice to seek an alternative supplier if this doesn't get fixed ASAP as I rely on the Internet for my job.
on 17-01-2022 19:15
Hi again Lee,
If your interent is down you should look at Check service status at the top of the page. You can also a run a test on your equipment from there.
If nothing is showing you should also try the Service Status number on 0800 561 0061. This often gives details of more local issues down to postcode level.
on 17-01-2022 19:32
@lansell82 neither @newapollo nor myself actually work for VM and are thus in no position to organise anything for you.
One thing I would say though is whoever you spoke to was absolutely NOT a technician, more likely a script reading person on whatever passes for minimum wage in Manila who actually understands as much about how the VM infrastructure works as my cat does, and absolutely DO NOT ever, ever pay for the ‘gadget rescue’ scam third party offering which I expect the £5 referred to.
on 17-01-2022 20:58
Ah ok, thanks - I simply cannot believe the service from VM. P!ss poor! And they want to hike the prices in the next month or 2 - for what I've experienced so far, they should be decreasing their costs to align with the lack of service they actually provide!
You both have been very helpful and I appreciate that
on 20-01-2022 12:30
Hey @lansell82,
Welcome back to the community and thanks for taking the time to post here on the forums.
Sorry to hear of your connection issues at the moment, I have been able to look into your account and can see an issue with the power levels supplying your hub. This issue would need a technician visit to resolve.
I can arrange the appointment from here but would need to confirm a few details via a private message, that I will drop over in a moment.
Regards,
Steven_L
on 20-01-2022 20:49
Hi Steven,
So why couldn't the so called technician I spoke with the other day see this issue for me instead of pushing me to pay more money per month to boost the signal from my hub ports? Surely you must agree that that is unacceptable service.
I've now waited over a week to be told this. I am furious that this issue is still on going and it's making my job harder with the signal dropping intermittently.
Can you arrange for your team to call me please as I'd rather talk to someone about the issue...and someone who actually knows what they're talking about than some scammer on the other side of the world!
on 24-01-2022 08:12
Thanks for the update @lansell82 and I hope that the technician can get all of your issues resolved on their visit.
Regards,
Steven_L
