Andyd2
Just joined
WiFi connection
I’ve recently had virgin broadband installed (last week) and my daughters are continually moaning about dropping connections, is there a booster available or can I have a second hub installed upstairs?
  • 19.28K
  • 1.68K
  • 4.22K
Re: WiFi connection
your limited to 1 hub per property, to improve wifi connectivity could look at:
Visit http://192.168.0.1/ and login with your password (located on the bottom of your hub).
In the menu on the left, navigate to Advanced Settings > Wireless > Wireless Signal.
At the bottom of the page you will find the “Smart WiFi” section. Here tick the box labelled “Disable Channel Optimization” and apply the changes.
https://community.virginmedia.com/t5/Networking-and-WiFi/Getting-a-better-Wireless-Network-Signal/td...
https://help.virginmedia.com/system/templates/selfservice/vm/help/customer/locale/en-GB/portal/20030...
there is 3rd party hardware such as access point, home plugs etc.. but would try those guides first
Click to learn more about VIP
Use Kudos to say thanks
