  • 7
Message 1 of 11
WiFi connection keeps dropping
For the last several weeks, my WiFi network has been dropping intermittently, some days worse than others. Today it has dropped five of six times between 9am-11:45am. It drops for around two minutes each time, and for all devices on the network, regardless of proximity to the Hub 3.
It’s rare that it drops at night, but has happened once or twice. Mostly it happens during working hours.
I recently extended my contract and the call handler said he had to push an update through to the Hub 3. It seems like the WiFi dropping has been occurring since then, but that may just be coincidence.
channels
13230000006.538256 qam24
21390000004.637256 qam1
31470000004.637256 qam2
41550000004.637256 qam3
51630000004.638256 qam4
6171000000537256 qam5
71790000004.937256 qam6
81870000004.837256 qam7
91950000004.838256 qam8
102030000004.838256 qam9
112110000004.638256 qam10
12219000000538256 qam11
13227000000538256 qam12
14235000000538256 qam13
152430000005.138256 qam14
162510000005.338256 qam15
172590000005.438256 qam16
182670000005.638256 qam17
192750000005.838256 qam18
202830000005.638256 qam19
212910000005.538256 qam20
222990000005.838256 qam21
23307000000638256 qam22
243150000006.138256 qam23
1Locked38.61210
2Locked37.67350
3Locked37.63890
4Locked37.61740
5Locked38.61710
6Locked37.31200
7Locked37.61100
8Locked37.6920
9Locked38.6680
10Locked38.61300
11Locked38.61200
12Locked38.6870
13Locked38.6950
14Locked38.6890
15Locked38.61120
16Locked38.61270
17Locked38.91040
18Locked38.6800
19Locked38.91170
20Locked38.61480
21Locked38.61520
22Locked38.62070
23Locked38.61490
24Locked38.91340
Upstream:
15370002650.8512064 qam2
23259996950.8512064 qam5
33939998350.8512064 qam4
44620003150.8512064 qam3
1ATDMA0010
2ATDMA0020
3ATDMA0000
4ATDMA0020
  • 7
Message 2 of 11
Re: WiFi connection keeps dropping
Network log:
27/10/2020 10:01:46noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 08:26:20criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 03:42:20noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
25/10/2020 03:42:20ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 09:11:16criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
23/10/2020 03:30:13noticeSW download Successful - Via NMS
23/10/2020 03:26:45noticeSW Download INIT - Via NMS
20/10/2020 15:25:15criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 05:52:4noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
20/10/2020 05:52:4ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 22:16:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 17:52:6noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/10/2020 17:52:6ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 12:25:14criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 09:46:1noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
13/10/2020 09:46:1ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/10/2020 00:42:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/10/2020 16:14:1noticeDHCP Renew - lease parameters tftp file-cmreg-vmdg505-bbt057+voc-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/10/2020 16:14:1ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/10/2020 16:13:59Error
  • 11.82K
  • 925
  • 1.52K
Message 3 of 11
What is your connection like using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
  • 7
Message 4 of 11
My BQM
Thanks Mike!
  • 24.7K
  • 1.42K
  • 3.14K
Message 5 of 11
Upstream levels are a tad on the high side, but not enough to drop the connection per se.
Are wired devices also losing their connection?
  • 7
Message 6 of 11
Hey. We don’t have anything on a wired connection, and I’m not sure where the Ethernet cables are, so currently unable to test.
  • 7
Message 7 of 11
Hi, can anyone suggest anything further, or could the VM staff look into this? It looks like a lot of people on the forum are having the same issue - is this just down to more people working from home/staying at home and it’s putting a strain on the network?
I’ve just had a work meeting for an hour and lost connection twice in that time.
  • 24.7K
  • 1.42K
  • 3.14K
Message 8 of 11
They will get to it here but it can take a week or so
  • 7
Message 9 of 11
Ah okay, thanks Gary 🙂
  • 7
Message 10 of 11
Update - has been dropping several times per hour this morning.
