  • 5
Nattz
Message 1 of 11
WiFi connection issues. Dropping
Hi, I have been having issues with my connection that tends to drop out of nowhere. In addition, it was rather bad today as the connection was dropping every 10 or so minutes.
Any ideas how to resolve it?
Thank you.
  • 5
Nattz
Message 2 of 11
Re: WiFi connection issues. Dropping
To add, I now tend to have high ms from time to time and cannot explain the cause.
Considering the speed I am on, I should not be affected by such a factor unless I overload the line, which is not the case.
  • 12.03K
  • 443
  • 1.07K
Message 3 of 11
This by wire or wireless?
Post your downstream, upstream and logs from the hub.
  • 5
Nattz
Message 4 of 11
Thank you for your reply.
It is wireless.
Downstream bonded channelsChannel Frequency(Hz) Power(dBmV) SNR(dB) Modulation Channel ID
129900000011.138.6256 qam21
232300000011.938.6256 qam24
331500000011.538.6256 qam23
43070000001138.6256 qam22
529100000011.438.6256 qam20
62830000001138.6256 qam19
727500000010.538.6256 qam18
826700000010.638.6256 qam17
925900000010.938.6256 qam16
1025100000010.638.6256 qam15
1124300000010.838.6256 qam14
122350000001138.6256 qam13
132270000001138.9256 qam12
1421900000010.938.6256 qam11
1521100000010.838.6256 qam10
1620300000011.138.6256 qam9
1719500000011.438.6256 qam8
1818700000011.338.6256 qam7
191790000001138.9256 qam6
2017100000011.338.6256 qam5
211630000001138.6256 qam4
2215500000010.335.7256 qam3
2314700000010.337.3256 qam2
2413900000010.637.6256 qam1
Upstream bonded channelsChannel ID Frequency(Hz) Mode Power(dBmV) Modulation Channel Bandwidth(Hz) Symbol Rate (ksps)
1753700000ATDMA38.364 qam64000005120
1625800000ATDMA38.364 qam64000005120
1532600000ATDMA38.364 qam64000005120
1439400000ATDMA38.364 qam64000005120
Network LogDate And Time Error Number Event Description
2018-06-25 13:19:47.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
2018-06-26 11:17:57.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2018-06-28 18:27:50.0082000200No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2018-06-30 18:03:57.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=;CMTS-MAC=:6e;CM-QOS=1.1;CM-VER=3.0;
2018-07-01 22:05:39.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2018-07-02 02:23:18.0082000200No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2018-07-05 09:25:20.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2018-07-06 04:11:13.0082000200No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2018-07-06 05:18:26.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=;CMTS-MAC=CM-QOS=1.1;CM-VER=3.0;
2018-07-06 08:08:56.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2018-07-06 08:29:20.0082000200No Ranging Response received - T3 time-out;CM-MAC=CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2018-07-10 12:29:09.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2018-07-11 09:07:57.0082000200No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2018-07-11 12:25:47.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2018-07-11 15:51:05.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2018-07-14 09:25:21.0084000700RCS Partial Service;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2018-07-15 05:18:21.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2018-07-15 05:25:30.0082000200No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2018-07-15 16:57:31.0068010100DHCP RENEW sent - No response for IPv4;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
2018-07-16 04:36:45.0068010400DHCP REBIND WARNING - Field invalid in response;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.0;
I am not an expert, but I believe that my downstream levels need to be adjusted.
Thank you for your help.
  • 12.03K
  • 443
  • 1.07K
Message 5 of 11
The hub wireless is not that good which is likely your issue but you can have them downstream power levels lowered but don't think it will make much difference the unofficial limit is 15dBmV.
  • 5
Nattz
Message 6 of 11
Thank you for your input. Well, wireless is my only option considering where the hub is.
  • 12.03K
  • 443
  • 1.07K
Message 7 of 11
You can leave this post for about 7 days and the forum team can get someone out to do them power level or call it in.
For better wireless you can look at getting your own wireless router and use modem mode.
  • 15.16K
  • 510
  • 1.85K
Forum Team (Retired) Jen_A
Message 8 of 11
Hi Nattz,
Sorry about your disconnections. Though you mention them specifically in relation to Wifi performance I do think that the elevated downstream power levels are a factor and would like these to be reduced.
10dBmV is the threshold and yours are higher than that. Please reply to my PM (purple envelope icon, top right of page) and I'll schedule an appointment for you.
Regards,
Jen
  • 15.16K
  • 510
  • 1.85K
Message 9 of 11
Hi Nattz,
Thanks for getting back to me Smiley Happy I've booked the appointment in (details are in my PM) so just make sure you post an update on here so we know if it's fixed, or if you require additional support.
All the best Smiley Happy
Jen
  • 5
Nattz
Message 10 of 11
In order to avoid making any new posts, wanted to ask you if someone could have a look at Network Log as a number of errors (critical appear). For some reason, I lose connection and gain it back as soon as I disconnect/reconnect from wifi. Thank you!
