on 31-05-2022 15:47
Hi, I am on the Hub 4 1 Gig volt package and I have had the Wi-Fi boosters for around 3-4 months now. I have 2, and I have rearranged them around my house to find the best spots. However, after a few days of them being plugged in, it starts buffering up with Wi-Fi. It shows there's a connection on devices and shows ethernet is connected on my PC, but it struggles to load webpages. I can go on discord, do online calls but mainly webpages just stay blank. I have also noticed within games random ping spikes from 30 all the way to around 300 for periods of 5-7 seconds. any help on this? I have reset the Wi-Fi, had an engineer over, I have called up virgin so they can edit settings with my router...I don't know what else I can do.
on 31-05-2022 15:56
on 31-05-2022 16:00
on 31-05-2022 16:09
on 31-05-2022 16:16
on 31-05-2022 16:25
on 31-05-2022 16:29
on 31-05-2022 16:38
on 04-06-2022 12:42
Hello @TeddyTRK,
Welcome back, thanks for posting.
I am sorry for the issues with your Equipment.
I will send you a private message now, so I can see what more I can do.
Please look out for a purple envelope.
Many thanks,
on 04-06-2022 12:54
@Hayley_S wrote:Hello @TeddyTRK,
Many thanks,
straight to pm - not sure why - maybe some upfront help would be useful
to the op - lets start with the basics - do you have any wired connections - if so are they ok - if the input is rubbish then whatever wifi you have will also be rubbish - post some info from the hub
log into hub3/4 - 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labelled - upstream - downstream
