on 08-10-2021 12:31
Since upgrading to the Hub 4.0, my WiFi Pod is not working. How do I connect it to my new router?
on 08-10-2021 14:53
on 08-10-2021 16:16
I’ve had a look online and on the forum and I can’t find instructions on how to do it.
Do you know if there even are any on the web?
on 08-10-2021 17:22
You cannot do it, VM has to.
Call Customer Services on 0345 454 1111 or if you have a VM landline 150
on 10-10-2021 17:30
Hi Wine99
Thanks for posting.
The WiFi pod is linked to your router - all you should need to do is locate the pod next to the router, wait for the lights to go out on the pod and that should then be sync’d with the router. Potentially, you may need to reboot your router also. It should then work.
Best,
on 11-10-2021 13:19
This is not the case - I have had it plugged in next to the router already, and it did not connect to my new Hub 4.0
on 13-10-2021 13:36
Hello Wine99
Have you managed to get the new hub and pod connected?
Gareth_L
