  • 96
  • 22
grdunn123
Up to speed
WiFi Light Bulbs
Tried a cheapo Amazon light bulb a while back to work with my Echo but couldn't get it set up. I think the issue was down to the bulb only working on 2.4ghz wifi - I have the Hub 3 running at 350mbps so any idea what settings I need to change too make this work and will I lose out on any internet speed for other devices?
  • 5.87K
  • 452
  • 984
Hero
Re: WiFi Light Bulbs
The Hub3, as shipped by VM, has both the 2.4 & 5 GHz WiFi bands on the same SSID. What you need to do is go into the hub’s settings and give them names like xxx-2 and xxx-5, the password on both can be the same. You can then connect your 2.4 devices to the xxx-2 SSID.
There are 10 types of people: those who understand binary and those who don't and F people out of 10 who do not understand hexadecimal
