See this I have posted before
___________________________
If it is a wifi only issue, then on a Hub3/4, you can try separating the SSID's of the 2.4 and 5 GHz wifi bands by renaming them in the settings and at the same time switch off "channel optimisation" apply and save the settings. All wifi devices will need reconnecting to the best SSID at each location. Also use a wifi scanning App to find the best wifi channels to use (just select and use channels 1,6,11 on 2.4GHz) - this often helps Hub3 users get better wifi performance - but its still no substitute for getting better kit
🙂To address the wifi issues, VM now supply “wifi Pods” (no longer doing cheap and cheerless “boosters”). However, their Pods are only free to customers on the 1GB, Ultimate Oomph or Volt packages - is that you? If so they are worth trying - they should work for you.
If not… you will be charged £5/month. Its a simple solution and should work for you. However, you would soon pay off that cost by buying a "better" wireless solution that will be yours to own and use forever but it isn’t the simple plug and play option of the Pod(s).
Get either a… (1) Mesh System, (2) Wireless router, (3) Wireless access point (4) Powerline adapters, (5) A combination of (2,3,4).
£40-100 should sort it for most customers with an average property and usage.
