leehambrook
  • 13
Message 1 of 5
Wi fi pods not connecting to new hub
Hi all,
Virgin recently replaced my hub 4 with a new hub 4 and since then the 3 Wi-Fi pods I have at home are not working.
I assume this is because they are still paired with the old hub? With the no apparent reset ability my question is, how do I pair these with my new hub 4?
I’ve tried unplugging them for a few hours then plug them back in whilst rebooting the hub at the same time but unsuccessful.
Any help appreciated!
Tags (1)
  • 6.81K
  • 592
  • 1.78K
Message 2 of 5
Re: Wi fi pods not connecting to new hub
Call the equipment activation number they may be able to help. It's 0800 953 9500 and you will need the Hub serial number/MAC address from the barcode sticker, and your account number.
leehambrook
  • 13
Message 3 of 5
  • 6.81K
  • 592
  • 1.78K
Message 4 of 5
The Pods are "tied" to the Hub, so when you get a new Hub, they are supposed to be reassigned to the new Hub.
Call that number and check this has been done by VM.
Megan_L
  • 3.9K
  • 219
  • 391
Message 5 of 5
Hi Leehambrook 👋
Thanks for using the forums to get this issue with your WIFI pods looked into, I am sorry if this has been causing some frustration after your new Hub was installed.
I can see Adduxi already gave you some helpful advice on who to call to get this issue fixed, were you able to contact the activation team? 📞
Megan_L
