on 08-03-2022 15:45
Just wondered if anyone can help recently WiFi signal going from high to low causing disconnects on equipment. It is very intemitant in it's operation. Wondered if the hub may be getting a bit old or if any upgrades have been done recently.
on 08-03-2022 15:58
on 08-03-2022 17:04
on 10-03-2022 17:59
Hi thengineer,
Thanks for your post.
I'm sorry to hear you've been experiencing an intermittent connection with your wireless devices recently. I've had a look from this end and your signal appears to be fine, however we have identified some capacity issues on your 2.4ghz WiFi signal.
Can you please try factory resetting your hub and let us know if that helps? To do this, you'll need to stick a pin into the pinhole at the back of your hub for at least 30 seconds.
Let us know how you get on
