on 29-03-2022 20:03
I am 500mb and I can never get over 300 and when am up stairs lucky to get over 100mb
29-03-2022 20:19 - edited 29-03-2022 20:24
Yes thats normal thats wifi
If you think you can do better get your own wireless router with 1Gb ports with hub in modem mode
on 29-03-2022 20:20
@karlejackson80 wrote:I am 500mb and I can never get over 300 and when am up stairs lucky to get over 100mb
Can you confirm you get full speed on a wired device?
on 02-04-2022 11:30
Hi @karlejackson80,
Welcome back to our community forums and sorry to hear you are having issues with your WIFI speeds. We can understand the frustration caused and we want to best help.
As mentioned by @carl_pearce, do you get these speeds on wired devices? How long has this been ongoing? Have you also checked here for a local fault? virg.in/service
on 06-04-2022 17:09
Its actually worst on wired device
on 06-04-2022 17:40
VM do not guarantee wifi speeds as it's too prone to interference. If you wired speed is poor, it could be a bad circuit.
Post the power levels, Pre and PostRS errors and network log from the Hub. Also setup a BQM to monitor your circuit www.thinkbroadband.com/ping
Once done we can comment.
