26-07-2021 19:14 - edited 26-07-2021 19:34
Evening.
Received a wi fi booster pod today and the instructions are abysmal.
I've plugged in upstairs..... the lights have cycled from a turquoise, to a solid blue, to a solid green. Now it is blinking white on and off.
Does this mean it is working? I have absolutely no clue what each light means.
Only point to note is that I only use my Hub 3 as a modem and use one of the below for the actual wi fi / router.
TP-Link Archer A7 AC1750 Dual Band Gigabit Wireless Cable Router, Combined Wi-Fi Speed Up to 1750 Mbps, 4 Gigabit LAN Ports, 1 USB Port, Supports OneMesh, Parental Control, Guest Wi-Fi, AP Mode, VPN https://www.amazon.co.uk/dp/B00416PTDW/ref=cm_sw_r_apan_glt_fabc_6H9ST2EGZRHNV7AK1P9J?_encoding=UTF8...
on 26-07-2021 19:25
on 26-07-2021 19:33
Right.
I'm no tech expert but I believe the hub is In modem mode as everything is connected to TP link, though my wi fi is still poor upstairs.
I did have the old style boosters connected to the HUB 3 up to earlier today and they were doing the job upstairs.
I was told the pod would be better and was sent one for free.
An hour after plugging it in it seems to flash between a blinking white light for 5 mins or so, then a blinking green light.
There seems to be no explanation of these lights anywhere..... really really poor, as are the installation instructions.
So, should I just stick with the old boosters and send this new pod back then??
on 26-07-2021 20:05
on 26-07-2021 20:58
Sorry, I know you are trying to be really helpful, however this part
"Set up your own route (in its settings) to have the WAN port set to be in DHCP (& Nat) mode, it may be pre-set that way anyway."
Went way over my head ..... Ive tried the settings and come across this (see pic).... but nothing else.
I'll try your other steps though, see if that sorts my issues. Thank you.
27-07-2021 01:04 - edited 27-07-2021 01:05
Your image was rejected as it contains private info (i.p.address etc).
If you look in the manual/instruction book for the Archer it should say how to have it in DHCP mode. It will be a little different on all routers - someone else may be able to tell you exactly where it is on yours, but it will be somewhere in the Network/Internet Settings.
This picture is how mine looks - it is set to DHCP from the drop down at the right of it.
