Wi-Fi pod problem
Monkey1960s
Why does my Wi-Fi pod keep disconnecting?
1 ACCEPTED SOLUTION
Accepted Solutions
Try moving it closer. Start with it in the same room and then walk it out until the connection is lost - then move back a bit.
Wall could be an issue - especially if it is a thick stone one, a Victorian iron rich red brick one or a modern plasterboard wall with inbuilt tinfoil insulation, etc.
3 REPLIES 3
Perhaps its too far away from the Hub. Have you tried moving it closer?
Hi, it’s one room away, about 25’, through a wall.
