Hi @Mammyryanrhys
Sorry to hear of any WiFi issues.
Just to confirm you're using the Pod whilst adhering to the below;
• The Hub must be in 'Router Mode' and not have been changed to 'Modem Mode'
• Channel Optimisation must be left on
• The SSIDs must be the same and broadcast enabled
• The SSID must be password protected
• The Passphrases of the SSIDs must match
If so, great.
Going forward, please use the Connect App 👉 https://www.virginmedia.com/broadband/connect-app - when downloaded, you'll be able to do a wireless scan in the property. This will check for any coverage blackspots, it'll try and optimise where possible and if a further Pod needed, you'll be prompted to order.
Best wishes.
