  • 9
Thesaint1967
Message 1 of 22
Why does the engineer get a higher broadband speed than my own test?
I have the 200mb/s broadband package, but when I use a wired test it's never more than 70mb/s. The engineer came out yesterday and he got 200mb/s on a wifi connection.Albeit it was at 8am in the morning on a Sunday after the clocks went forward so most people were still in bed! I use a iPad 2 for a wifi signal and a Sony vain laptop running 8.1 windows for a wired with a cat 7 Ethernet cable. When I have rung virgin technical dept (offshore) they said its due to me not having Windows 10 or I needed to have an updated Ethernet cable as previously I was using a Cat 5 cable. I use the popular test app by ookla and this morning it came out at 43 it doesn't even have on the Internet test higher than 50mp/s on the test graphic.
Can anyone suggest and I don't use a current mobile phone to test either
  • 3.65K
  • 201
  • 608
chenks
Community elder
Message 2 of 22
Re: Why does the engineer get a higher broadband speed than my own test?
you can't use WIFI to test anything as it's too unreliable.
ethernet tests are the only way to test.
is it possible your laptop is faulty? can you use a differnet device on ethernet to test?
  • 9.43K
  • 978
  • 1.48K
Message 3 of 22
There are many reasons why the laptop isn't receiving full speeds. Try testing this way first and see what it gets.
Check that the Sony has a gigabit enabled network card (not just 10/100) and has the up to date drivers - it might not as you are on W8. Use a new Cat5e/6a ethernet cable (your Cat7 should be fine) to connect it directly to the Hub - which you have put into modem mode (to ensure only your laptop is connected). Then, boot up your device into "safe mode with networking". This is to disable any software on it that could be limiting speeds (lots of examples of that on here) and run the test at "speedtest.net" on 2 different browsers one of which is a fresh download of one you haven’t previously used (e.g. Firefox, Opera, etc). There are several examples on here where a browser (usually Chrome) is corrupted in some way and limits speeds.
Report back what you get.
EDIT: forgot to add the iPad will get much better speeds when you connect it to the 5GHz network - mine gets ~220mbps close to the router but only 80-90mbps in the same place on the 2.4 network - what network is your iPad connecting too?  What Hub model do you have?
  • 13.2K
  • 1.01K
  • 3.07K
Message 4 of 22
i dont disagree in principal but the op posts this
____________________
Tony
  • 3.65K
  • 201
  • 608
chenks
Community elder
Message 5 of 22
which is fine, but on what WIFI device? and how many times was it tested?
and i'd be curious as the why an engineer would do any test via WIFI.
  • 4.71K
  • 319
  • 790
Roger_Gooner
Superstar
Message 6 of 22
WiFi will never be better than wired. If you have 200Mbps on WiFi your wired speed must be at least that.
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG1008D 8-port gigabit switch, V6
  • 3.65K
  • 201
  • 608
chenks
Community elder
Message 7 of 22
not entirely true. you could have 5GHz AC WIFI but a 10/100 ethernet port.
WIFI would well exceed ethernet in that situation.
  • 4.71K
  • 319
  • 790
Roger_Gooner
Superstar
Message 8 of 22
It's obviously the speed coming out of the hub which matters, and all the hub ports are gigabit.
  • 3.65K
  • 201
  • 608
chenks
Community elder
Message 9 of 22
yes but you've got a 10/100 device connected to the gigabit port then all you'll get is max 100Mbps.
so if you're running a speedtest then the testing device needs to support gigabit.
as i said, i'd be surprised if any engineer did a "speed test" using a WIFI device, so i'd be taking that part of the OPs post with a pinch of salt.
  • 12.61K
  • 482
  • 1.12K
Message 10 of 22
We don't have that problem with todays simple routers....having a NAT router with a device with a 100Mb link to the hub does not impact a device with a 1Gb link to the hub for the internet.
